Question about Cuisinart DLC-1 Mini-Prep Food Processor
Lost the manual and need to know How to use the Cuisinart Mini Prep Food Processor model 5900
SOURCE: Cuisinart Prep 11 Plus Food Processor - Help!
Not sure if you found the solution by now but we recently had a similar issue. Make sure the bowl is put on such that the handle is facing the front of the processor. There is a little black button that gets depressed when the lid gets put on. We had to get the thing to work one night and spent hours trying to get the processor on and then trying to get a blender to work before finding the problem.
Hope this helps.
Posted on Nov 28, 2008
SOURCE: replace the spindle on Cuisinart DLC-7 Food Processor
Did you contact Cuisinart? I just sent my DLC-7 to Cuisinart for repair. The start switch does not latch and works as a pulse switch.
Posted on Jan 07, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: need manual for food processor
The manual is available for free at Cuisinart's website
www.cuisinart.com
-Tha Mp3 Doctor
Posted on Jan 17, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Posted on Mar 17, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Lid stuck on bowl of my Cuisinart Mini Prep Plus.
Generally they twist off, but on the DLC-2, if the lid won't come off, a replacement bowl and lid is around $18.00
Posted on Mar 20, 2009
Need user manual
Google DLC-2 Mini Prep Plus Food Processor manual and you get https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=DLC-2+Mini+Prep+Plus+Food+Processor+manual
May 03, 2016 | Cuisinart DLC-2 Mini Prep Plus Food...
My Cuisinart mini food processor has worked beautifully. Now the blades are turning but nothing is being chopped or ground. Thanks!
the drive connection for the blades has probably stripped out and not driving the blades when there is work to do
Nov 08, 2015 | Cuisinart DLC-2 Mini Prep Plus Food...
The lid for my mini cuisinart hit the tile floor and broke. I need a replacement. I live in Vancouver, British Columbia. Do I buy it on line, or in a store near by. Thank youNora
We don't stay in the same vicinity, so I don't know precisely where you can get the replacement. So I would suggest you order it online.
Click on the below link to order for the replacement.
http://www.kitchenworksinc.com/Cuisinart/Cuisinart-Mini-Prep-Parts.aspx
Please let me know if your need more assistance....
Regards.
Aug 24, 2011 | Cuisinart DLC-1 Mini-Prep Food Processor
I have all the accessories to juice an orange but can['t make it work in my mini prep pro food processor
I would just remove and replace the work bowl, and then reposition the strainer, etc again. I don't know what the magic is, but if I just put everything back in palce exactly as the user manual lays out, I can always get it to work again.
-Tha Mp3 Doctor
Mar 11, 2009 | Cuisinart DLC-2 Mini Prep Plus Food...
Need manual for Cuisinart Prep 11 Plus
You can get the manual here at this link.
http://www.cuisinart.com/manuals/index.php?item_id=53
Good Luck and Please Rate FixYa!
Dec 25, 2008 | Cuisinart Food Processors
Dec 24, 2008 | Cuisinart DLC-2 Mini Prep Plus Food...
Cuisinart DLC-1SS Mini Prep Chopper
Here is a link to the manual
Also, this product has an 18-month warranty
http://www.cuisinart.com/share/man/69_man.pdf
-Tha Mp3 Doctor
Jul 29, 2008 | Cuisinart DLC-1SS Mini Prep 2.63 Cups Food...
Cuisinart DLC-1 Mini-Prep Food Processor Logo
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
