Question about Saeco Magic De Luxe Espresso Machine
Machine leaking water from service door behind where the pucks collect. water pools/collects into the excess ground coffee tray. any suggestions?
  • 1,089 Answers
Hi
Trying to understand what you are talking about, but if you have water in the top left side of the brew unit, its your thumb screw. If you have water under the brew unit Its the drain for the pressure release. remove the brew unit. The injector behind the brew unit on the machine has a drain and it can get clogged with coffee residue. If there is water below the injsctor the drain hole is inside and towards the front of the machine. A long zip tie inserted in the drain aimed down towards the front will usually find the drain hole and clear it, then take some hot sudsy water and flush the drain.
If its the thumb screw you will ahve to get a new one but be sure to remove the extra nut on the filter screen shaft before installing the new one.
Posted on Jan 01, 2011
Why is there a lot of water in the drip tray after each use?
Two to three teaspoonful water overflow after each espresso is normal. That is why the tray is there.
If water collection in the tray is excessive and programmed espresso is smaller, then there is cause for worry.
Jan 29, 2016 | Jura Capresso Impressa Coffee Makers &...
Coffee is weak and pucks are being sent out on the wrong side of the coffee maker - 180 degrees away from the puck collection tray.
You need o take mahien apart to service also see the spoil if it loose to move coffee cake in the wrong place
Jun 09, 2015 | DeLonghi Magnifica Coffee Makers &...
Water in disposed coffee container jura impressa z5
You may have to clean the unit using cleaning tablets, also there is a flap in the bay (remove the tray and use flashlight, sometimes it cakes up and moisture collects. Final thought is you may need to send it in to Capresso/Jura for service. Mike
Mar 08, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
The grounds tray was shoved in backwards and removing it now will break the machine
Try applying hot water around the dish to expand and unstuck while gently but firmly pull the tray. It went in so must come out.
Dec 20, 2013 | Jura Capresso Coffee Makers & Espresso...
When the coffee grounds dump into storage tray, it doesn't stay in the puck shape it used to
When things get wet to they tend to spread apart when pressure is released - normal thing to happen. Only option is to use orange juice instead of water.
May 20, 2012 | Gaggia Titanium Espresso Machine
There is a excessive amount of water collecting in the drip pan, and I need to empty the pan every other day. Before it was once every two weeks or so. I have taken the "unit" apart to clean the...
Hi
Excess water going into the drip tray is usually an indication of the grind being to coarse. If your pucks are not solid but just fall apart this is the case. When the grinder is grinding, turn the big knob in the bean hopper down 2 numbers smaller and see if this changed. If you have a second knob in the bean hopper change the to the plus side, but not all the way to the plus. Do this first before you change the grind setting. Excess air between the grind allows more water in the brew unit and when it is done it goes into the drip tray.
Mar 23, 2011 | Solis Master 5000 Espresso Machine
Water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
May 19, 2009 | Solis Master 5000 Espresso Machine
Krups XP 9000 - Check Collecting Tanks
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={EBDB947E-33FB-42E0-B662-0E13E8D1D4FB}&SelectedProdRef=XP9000
here is a link to the manual. u need adobe to open it
Feb 26, 2009 | Krups Super Automatic XP 9000 Espresso...
Leaking water
Take out the brewing unit and look in the chassis behind where the brewing unit was, you will see a little hole, put in your finger and make sure the hole is clean.
Have a nice day
/Mirran
Oct 20, 2008 | Saeco Vienna SuperAutomatica Coffee...
Leak
if you clean your brew unit and coffee lines infrequently you're coffee may taste differently when you do get around to cleaning them.
If you are not happy with the taste, I would receommend the following steps
1. A Good Descale (See our article here for on Descaling your Coffee Machine for details) - This will remove excess mineral build up.
2. Try a Saeco Cleaning Tablet in your brew unit - this will remove excess organic build up (Coffee and Grease)
3. Use only filtered water
4. Rinse your brew unit every time you empty your coffee dreg drawer
That should bring your machine back to optimal coffee making condition. If you are still not happy, try some different coffee blends for a while - a change can be as good as a holiday
Paul from Coffee Shrine
Saeco Coffee Machine
Aug 20, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
271 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
