Question about Maytag Dryers
Maytag Mod DG210 how dows the belt loop around motor
  • 156 Answers
SOURCE: replacing maytag dryer belt
hard to explaine i will try put belt on the motor pulley then lift the belt tightner back pulley so now the belt goes around motor pulley up across the bottom of belt tightnerthen on up around drum
Posted on Feb 28, 2008
mikedurland
  • 481 Answers
SOURCE: Replacing dryer belt
  • Just like this but imagine the roller as being a semicircle.
put pressure on the tensioner with the belt and loop the belt under the tensioner to the motor.
  • this is a diagram for a whirlpool/kenmore/roper/estate dryer, i don't know the brand of dryer you have.
look here is more diagrams of different brands. http://www.repairclinic.com/0079.asp
let me know if you need more help Mike
Posted on Jul 04, 2008
mikedurland
  • 481 Answers
SOURCE: Fitting new drum belt to Simpson Dryer
it all depends on the brand of the dryer. go here for diagrams for a bunch of brands.
Posted on Jul 06, 2008
hiltonjug
  • 612 Answers
SOURCE: My Maytag MDE308DAYW needs a new belt. Belt was
If you go from the top. The belt goes down the drum, between the drum and idler pulloy,under the idler then pull it over to the top of the motor pully and loop over it. When it comes out from under the motor pully it goes under the drum and over to the other side of the drum, and back up to the top of the drum. I hope this makes since.
Please rate solution if helpful
Posted on Aug 28, 2009
Testimonial: "Thank you for the advice. "
hunter19_46m
  • 7482 Answers
SOURCE: Belt broke on Maytag dryer DE410. I purchased a
The squeak may be coming from the drum rollers, check them to see if they need lubrication.
I recommend that you use a good grade of machine oil to lube them such as 3 in One oil. Lube them at the shaft of the roller. Also check the rollers to see if they have flat spots on them, if they do then they will need to be replaced.
Recheck your location of the idler arm bracket with pulley to see that you have it in the right location and that the spring is also in the right location. Look for wear spots on the frame and idler arm and match them up.
Good Luck,
I hope this helps
Posted on Oct 13, 2009
I took the dryer apart and lubercated the belt and now I cant put the belt back on. How do I do this?
Hi buttcrackplu...
The belt will go around the drum,around the motor and idler pulleys....
Go to this webpage to see how the belt is routed.
Free Answer.,..Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Apr 18, 2011 | Maytag Neptune MDE4000 Electric Dryer
Belt does not go back on with enough tension.
Are you replacing a broken belt? If so then the belt should go flat side of belt in toward drum. Make sure the belt is not in the slight channel in drum put belt from right under guide around idler then insert loop under idler and attach loop to motor. Should end with ribbed side of belt on pulley.
Nov 20, 2010 | Maytag Dryer Idler Pulley for Large...
How do you replace the belt on a Maytag clothes dryer
frist unplug dryer then take front panel off dry then take lint housing off there 4 screw on both side take that off remove broken belt put new belt on around dryer drum an loop belt over white idler pulley an around motor pulley idler pulley put tension on the belt
Apr 24, 2010 | Dryers
ANt diagram of how the belt goes on the Maytag
pull the loop on the bottom of the tumbler once you have it warped around and hanging free
pull that loop twords the motor under the idler pully
both side of the loop
pull the loop twords the motor hub, you may need to left the idler pully to gain a liitle slack
once on the motor let go of the idler and it should tighten the belt
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Aug 28, 2009 | Maytag MDE308DAYW Electric Dryer
Need belt diagram for Performa PDET920AYW dryer
Flat side of the belt goes agaist the drum. The diagram is on the new belt
Aug 08, 2009 | Maytag PYE2300AY Electric Dryer
Which wa does the belt on a Maytag Atlantis dryer run around the motor and idler pulley. I have the belt groove side down, which is the way it goes in the Atlantis, but I couldn't find a schematic for the...
Hi you're correct in putting it groove side down. Now make a loop, like when you first started tying your shoes with the slack around the drum. Push the entire loop just beneath the idler pulley through the metal channel and apply pressure to the idler pulley assembly. pushing it towards the motor pulley until you can get the loop you are holding over the motor pulley and Waa Laa you've installed your new belt. Good Luck!
Dec 10, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
The belt for my maytag dryer seems to long and i have it on the pulleys and the drum. am i suppose to loop again around the idle pulley
route it from the motor straight up around the drum, from the bottom of the drum back to the motor, and then out around the tensioner
Apr 16, 2008 | Dryers
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Dryers Logo
49 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
