Question about Cycling
Can i lock my schwinn elliptical 418 so that it does not move when not in use (for child safety)?
4 Suggested Answers
SOURCE: error code 1 on schwinn elliptical 418
E1 error seems to indicate that the servo which controls the elliptical resistance is stuck. Here is how I fixed this (without using a "crank puller", which would be quicker by far).
You will need a very short phillips screw driver (snub nose), a long phillips screw driver, an allen key set, and crescent wrench.
- Remove the batteries from the unit.
- Remove the screws from the plastic housing (with the long phillips screw driver) on the left side. Do not forget the phillips screws at the front - they are smaller screws so don't mix them with the others. This will allow the plastic housing to flex and move around, but not come entirely off.
- Using the crescent wrench, remove the nut holding the left pedal to the crank. Carefully note the order of the washers on the crank attachment.
- Using the allen key, remove the little pedal attachment piece on the left crank arm.
- Using the short phillips screw driver, carefully reach inside the plastic housing on the top and remove the four screws holding the plastic plate on the outside of the fly wheel/crank. You will need to rotate the crank wheel to reach each of the four screws in turn on the inside of the case.
- Pull off the plastic cover for the wheel.
- Reinsert batteries and gently help the revealed cable (bottom) retract the magnet plate. In my case, the servo worked fine again after helping it retract the magnet plate that was somehow stuck/wedged.
Reverse steps to re-assemble.
Posted on Feb 20, 2010
SOURCE: I have a 418 schwinn elliptical and the screen
hi there, did you get your problem solved? I am having the same problem and are searching everywhere without a satisfactory answer. hope you can help out!
Posted on Apr 30, 2011
ercupa190
  • 12223 Answers
SOURCE: will the schwinn elliptical 428 console work on the model 418? or any other console work on the 418 model
this a matter from the supplier or factory. You must get support via ONLINE chat or phone. Since the CPU+Eprom+Rom can be information different, only the factory has the properly answer.
God bless you
Posted on Sep 27, 2012
Will the schwinn elliptical 428 console work on the model 418? or any other console work on the 418 model
God bless you
Sep 26, 2012 | Exercise & Fitness
Looking for manual for 418 elliptical repair and user type
Hello Mug,
Please download the Schwinn® 418 Elliptical manual from the link provided below :
http://download.dfxi.com/supportdocs/AM/Schwinn/SCH_418-428_AM_web.pdf
Oct 10, 2011 | Schwinn Exercise & Fitness
The computer on my schwin 418 eliptical does not work. Is there something I can do to fix it myself? Where can I get it serviced?
Call Schwinn customer service (actually Nautilus) at 1-800-nautilus if it is broken so you can order a new one or they will send you a new one if you are under warranty. They are very helpful. You can also check the power connection on the bottom or make sure the wire harness in the main pipe in the center is properly connected if the system is brand new and not working.
Jan 04, 2011 | Schwinn 430 Elliptical Trainer
I have a 418 schwinn elliptical and the screen went blank while I was using it. I changed the batteries and looked at the wires that connect to the console everything looked good but still nothing. What do...
Oct 21, 2010 | Schwinn 430 Elliptical Trainer
I am trying to remove the covers on my Schwinn 418 elliptical trainer. The covers hang up on the crank/flywheel. The repair manual says to use a crank puller. Is there another way. If not what type of...
Hello there. Unfortunatley there is no way other than removing the crank arms. You do need to remove the nut on the axle and you will need a crank puller. The puller is available at any local bicycle shop for around 10-15 dollars.
Good Luck Tim
Jan 31, 2010 | Schwinn 430 Elliptical Trainer
Schwinn 418 Computer does not come on.
Did you ever fix this? I am having the same problem...
Dec 10, 2009 | Schwinn 430 Elliptical Trainer
Cycling Logo
200 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
