Question about Mitsubishi Televison & Video
I have a mitsubishi 55in big sreen hd 1080 medallion tv . now and then the sreen at the top will get a black bar acrossed it if i slightly hit on the top the full picter will come back in please help.
    Brigadier General:
  • 8,909 Answers
There is a dry joint on the solder side of the frame output section.
Follow the wires from the scan coils on to the board. Two of the connections will go to the line stage and two will go to the frame stage.
Check the connections here and find the frame output stage and check there also.
Re solder as required and that will fix your problem.
Posted on Jan 01, 2011
  • specialistel Jan 01, 2011
    An engineer should be able to repair the fault in less than an hour.
    Hope that gives you an idea on cost.
Mitsubishi medallion hd 1080
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Mar 27, 2014 | Televison & Video
I have a HD 1080 Medallion TV and I just changed it to Direct TV and the color is now in Black and white. Is there anything on the remote to fix this?
More likely the cables from the Direct TV box and the TV are incorrectly connected. My guess is that you have red, green, and blue cables that carry to video signal and they are incorrectly connected or one of the cables is bad.
Sep 10, 2013 | Mitsubishi Televison & Video
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
I have a mitsubishi Medallion hd 1080 and the picture is bad, colors off plus there is a yellow section along the top o the screen. Can this be repaired
Yes,U know how to solders?Ur convergence it dead,must replaced it with a convergence kit,use what in that kit.Tries these websites for the convergence kit.Tv repair World.com,Tv repair Kits.
Nov 10, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
Can't loate bool;et for Mitsubishi HD 1080 Series Medallion
it is usually in the Audio settings,sometimes by the CC settings, if you go to the TV and enter th menu from the set, go thru one at a time until you find the spot to turn it off, it is under options or Menu on the remote also, there maybe an SAP Option on the remote itself, but you may have to press another key first like a "Function: Key.
I hope this helps some, if so please give me a good (fixya) rating. Thanks and have a Blessed Day
Apr 08, 2009 | Televison & Video
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
May 30, 2008 | Televison & Video
Open Questions:
Televison & Video Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
