Question about JVC RV-B90 Boombox
Radio station presets
When there is a power outage, the radio channels change. I have had no luck finding a replacement manual. Can you tell me how to make the radio stations stay put?
Look in the back of the boombox where the large D-cell batteries are. Beneath the large batteries there is a location for smaller AA size batteries. The AA size batteries are used to maintain the radio station pre-sets when the unit is unplugged. Check to see that these batteries are installed or if they need to be replaced with new ones.
Posted on Sep 22, 2008
Sanyo Model Number DP26640 Channel search
Did your problem solved. if you Need any assistance feel free to conact back.
Mar 31, 2012 | Sanyo Televison & Video
Need owners manual for 100 channel bearcat 860xlt lost all channels in power outage don't remember how to program it
  • When you get to the link click on "Click here to start download from MediaFire.." and the PDF will download onto your computer.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 13, 2011 | Uniden BC370CRS Base Scanner
Radio Shack Catalog # 21-1926 FRS radio manual needed. Else tell me if I can change channels 1 - 7 to LO power out. Suspect they are hard coded for HI power out.
In short channels 1-7 and channels 15-22 are GMRS channels are not supposed to be operated by anyone that does not have a GMRS (General Mobile Radio Service) license issued by the FCC. They automatically run on high power. Channels 8-14 are FRS (Family radio Service) and can be used by anyone and are set to run on Low Power. The power is not adjustable with this radio. So now for the manual. Uniden made this radio for Radio Shack. So this manual is for the same radio only with the actual Uniden name. Same exact physical radio same exact manual.
Regards, Tony
Apr 22, 2011 | Radio Shack 21-1926
  • No the power is unadjustable for any of the channels. The first 7 channels are 5 watts and authorized for use with a license only, Even though everyone uses them just though I would give you the heads up on that. The remainder of the channels are 4 watts and all transmit on UHF (Ultra High Frequency)
Regards, Tony
How could i program/change the freq of my motorola gp2000 manually
I don't think that you could program/change the freq of your Motorola GP2000 manually since newer Motorola radios today everything is done by computer and programming sotfware. You need to have software for GP2000, radio interface box ( RIB) and programming cable for GP2000 radio and these devices are not cheap. The best way is to contact a local repair shop to have it done for you or find a two-way radio technician, he could do this if he has all the test equipments required.
Oct 21, 2010 | Motorola GP300 Compatible 2 Way Radio...
How to get TV audio on the FR300 radio?
Your TV band radio won't work anymore now that the US has switched to digital broadcasting. The frequencies now in use aren't the same now, so the radio can't receive them. Plus, the radio doesn't have the circuitry to decode the digital sound even if it could pick up the broadcasts.
Sad to say, you have a radio that now picks up only AM/FM/weather and static. Also, as far as I know, nobody is yet marketing a radio for TV sound with digital capability. All you can do during a power outage is use a new TV with battery capability and digital tuning.
Mar 02, 2010 | Eton FR300 AM/FM/Weather/TV Radio
After a power outage my rca 36 inch pip changes channels
the manual buttons on ur tv set seems to be stuck, take a look for any damage or corrosion or for anything
May 10, 2009 | Televison & Video
Uniden Bearcat BC60XLT 10 Channel 10 Band Radio Scanner with L/O on every channel #
Turn off power, hold down the 2, 9 & L/O buttons while turning the power back on.
Aug 09, 2008 | Uniden BC60XLT Handheld Scanner
Instructions on how to change channels on TECHNIKA MODEL TA-13
Basic Instructions for Technika Model TA-13
On this model there are 7 buttons:
Left to Right these are:
PTT, Push to talk on lh side as screen faces you.
Torch Light (on rh side)
Assuming you have used the power button to turn on the radio, the default channel after installing the batteries is 1 or else the last channel to be used.
Press the power/menu button once-briefly, (the current channel will flash for about 10 seconds.) Then use the Up and Down arrows to change channel. Wait for the remaining few seconds and the radio will return to normal operation.
Press the menu button twice, the letter H or L will appear and can be altered by the Up and Down keys to change the power level of the radio. I think this is transmit power which may help you avoid infuriating local taxi companies. Switch back to High power when you're about to go out for the night and need a ride.
Press the menu button three times. This will turn off Squelch control and make a terrible din. Not terribly useful unless you want to pick up a really weak signal (or find out where the taxi driver has taken your neighbour.)
An easy way of finding a channel is to press and hold the Scan button and then the device will rotate through the available channels looking for a signal. When someone transmits, the scan will pause and you can capture it by pressing the PTT button for a second or two. I have found this helpful in pairing my radios with other sets, or picking out channels that work with friend's radios.
Finally, Volume control is really simple, just up and down when not in any other mode.
I had the instructions, which I think included a mention of all available channels I'll scan and post them if ever I find them. hope this part helps though.
Jan 29, 2008 | Radio Communications
Unwired UFRBS10 2-way radio
I tried to find the user manual but no results mostly of the FRS radios, has a menu wich incluides the Vox feature, please tell me if you have a little face icon, this could be the Vox field to turn on or off. Or tell me what icons you have on it in the menu
Mar 01, 2007 | Unwired UFRBS10 (14 Channels) 2-Way Radio
JVC RV-B90 Boombox Logo
267 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
