I need the wiring diagrams for the DPS-270 and DPS-175 time base correctors
The Broadcast Store sells the Service Manual for $99
http://www.broadcaststore.com/store/model_detail.cfm?id=810349
Too much, agreed.
I have one too, and would consider buying and copying to split the cost.
Might be slightly awkward to copy.
Most DPS documentation was very thorough.
Posted on Jan 29, 2011
DPS-312AB-1A diagram
How to check whether the DPS 320-1A HP SMPS is working with out connecting it in to the motherboard
Sep 02, 2013 | Dell (DPS-312AB-1A) (dps312ab1a) 320-Watt...
Hi how to connect one 20amps contactor and a delay timer
Which delay timer do you have? 9 pin, 11 pin, etc?
What voltage are you using?
What is amp rating on timer?
Copy following links for general and specific wiring diagrams:
http://waterheatertimer.org/How-to-wire-pin-timers.html
http://waterheatertimer.org/images/10-pin-wiring2-1000.jpg
http://waterheatertimer.org/images/ON-delay-timer-diagram-900.jpg
Add a comment.
Gene
hh
Aug 20, 2013 | Intermatic WH40 - Water Heater Time Switch...
Pinout diagram for DPS-450FB
Pin configurations are available on the web site. Go to Support and input the data they require. Download the manual and your in business.
Feb 24, 2013 | Gateway 980 / 960 Server Power Supply...
Focus knob will not work
The focus knob turns on a threaded rod which passes through a focus lever, which is secured to the back of the primary mirror. The end of the rod where it passes through this lever is secured by 2 jam nuts, one of which has probably fallen off.
http://ngc1514.com/Celestron/disassem.htm
To fix this you will have to take the front corrector plate off, find the nut rattling around in there, and tighten it back onto the end of the focuser rod, as shown in the diagram. I'd use a little Loctite as well.
This is not difficult, and you can clean the inside of the corrector plate while you have it off. The only precaution is to mark where the corrector plate was, and replace it at the same orientation. Some opinion has it as being worthwhile to also get the secondary mirror centered on the corrector, and the corrector then centered in the end casting. An accurate rule or vernier calipers can be used. Don't tighten the screws on the corrector plate retaining ring much more than hand tight.
http://www.astromart.com/articles/article.asp?article_id=594
http://www.darkatmospheres.com/music/C11_Project/index.html
http://www.celestron.com/c3/support3/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=1655&nav=0,214
http://www.nexstarsite.com/OddsNEnds/SCTCorrectorRemoval.htm
http://www.laughton.com/paul/rfo/c11-disasm.html
Apr 29, 2012 | Celestron NexStar 4 SE Telescope
Lube stain on Secondary mirror on CPC 1100
Probably lubricant out-gassing which can collect than drip. Your choices are to contact Celestron service or do it yourself. DON"T PANIC! It is not that hard if you are brave.
1. Use a piece of masking tape on the corrector to the side of the housing.slice it carefully where they meet. This will insure correct alignment with the primary when you put it back together. (Correctors are sorted then oriented to,(as the name says) correct the primary.
2. Remove the corrector plate. Mark any shim locations with a marker on the outside of the corrector plate (remove after re-installation)
3. Make a solution of 50% distilled water and 50% isopropyl alcohol. (97% pure or better- I use 99% pure alcohol) 1 drop of dish detergent may need to be added,depends on the stain.
4. Rinse the secondary until grease is gone. Do not rub mixture on mirror, just keep rinsing.
5. Rinse with pure distilled water,gently stand corrector up to dry.
6. Assemble the scope. Use the same water/alcohol mixture to clean up the outside of the corrector. Dampen cotton balls and wipe with VERY light pressure.Wipe once, throw the cotton ball out and use a fresh one. Do not make the cotton balls too wet, you don't want moisture to get under the corrector.
7. If the stain is really tough, acetone may be used without damage to the mirror surface.
8. Use surgical gloves to avoid fingerprints.
9. Lots of towels at work area in case the corrector slips out of your grip.
10. If you put it together correctly, minimum collimation will be required.
There have been a number of these problems cropping up lately, I think Synta is using inferior grease now.If you are really brave, clean the old grease
off and add one drop of lithium grease. Run the primary through focus range a few times to distribute.
If you do this, you can later flock the inside of your scope to increase contrast.
Dec 29, 2011 | Celestron CPC 1100 GPS (XLT) (70 x 280mm)...
Installed the timer last week, we have it to cut on at 4pm and shut off at 10pm, it will come on at the right time, and even shut off at the right time, but for the first time only, once it hits the 10pm...
Your clock motor is not correctly wired to the terminal block. Carefully review the connection diagram for the line and load leads and the timer clock leads. Somewhere in there you made a mistake when connecting the wires. If not there is a defect in the clock mechanism and you should replace it. For warranty information please refer to the instructions or the place you purchased it from for assistance.
John
Dec 14, 2010 | Intermatic WH40 - Water Heater Time Switch...
Changing out the hot water heater timerswitch
Nema 1 means indoor-only enclosure or box.
For example Nema 3R is raintight for indoor-outdoor box, which is typical for outdoor swimming pool timers.
If you have water heater timer, open following page for common timers with images, manuals and wiring for each.
http://waterheatertimer.org/Boxtype.html
Dec 27, 2009 | Intermatic WH40 - Water Heater Time Switch...
How to remove the corrector lens of a Nexstar 4
I would not try to remove the corrector plate-- the manual states to return the scope to Celestron if the inside of the corrector needs cleaning.
If removed the corrector has to be replaced in the EXACT position it was in before you took it apart-- the alignment between the front corrector plate and the rear mirror and the secondary mirror was done on an optical bench at the factory.
I doubt that will you notice or be able to see the small stain while you are observing--
Mar 15, 2009 | Celestron NexStar 4 GT (240 x 102mm)...
Clock on Intermatic WH40 Timer Switch does not rotate
Timers are a waste of time . I would disconnect it and get rid of it. Water heaters nowadays are so energy efficient and the thermostats take care of when it heats and shuts off. Your timer might save you pennies a year!
Feb 27, 2009 | Intermatic WH40 - Water Heater Time Switch...
Televison & Video Logo
290 people viewed this question
Top Televison & Video Experts
Electro Med Services...
