Question about Video Game Consoles & Games
I have finished setting upthe Wii fit and just about to start the body test but it keeps on telling me to step off the board and press A, even though I have not stood on the board. I have tried resetting but I still come across the same instruction. Can you help?
  • 492 Answers
It seems your Wii sensors are stuck, This is a hardware problem which requires you to open up the scale and should really be done so by a representative of Nintendo. Unless you know what you are doing, call up Nintendo or return it to the store and get another one.
Posted on Jan 01, 2011
Hi, I have just bought a Wii fit and game, on trying to set it up and do the body test, it keeps telling me to step off the board when I'm not on it and it won't let me continue. What can I do?
It looks like there is something wrong with the board. Try one of the following:
1. Power off the board and power back on.
2. Step on and Off from the board.
If this doesn't do anything, try this:
1. Power off Board
2. Power off the Wii and remove the main plug.
3. Put all on back after a minute or so and see if it does the same thing.
If it does the same thing, then I suggest you consult or return the Board to where you buy it from.
Hope this helps.
May 06, 2011 | Nintendo Wii Fit for Wii
My balance board keeps telling me to step off and press A in the body test setting up part. I step off and it keeps telling me to step off
The sensors need to be reseated.
  1. Take the batteries out.
  2. Take out the screws from each foot in every corner of the board using a Philips screwdriver. Remove the back cover.
  3. The sensors are located on each corner, it is a metal plate. Loosen the screws using TORX screwdriver.
  4. Re seat the small metal plates by putting it back. Don't screw too tight.
  5. Put the cover back and foot on. Put the batteries back in.
Dec 19, 2010 | Nintendo Wii Fit for Wii
My wii fit keeps say pleasae step off me and press a when i go to do the body test
Replace your Wii Fit Plus board and/or DVD disk. I had the same problem. The seller has gave me a new Wii Fit Plus set (instead of the 1st one), and everything was OK. I don't know if the problem was in the board or in the DVD disk.
Aug 14, 2010 | Video Game Consoles & Games
My wii balance board keeps telling me to step off and press A, while I am not on it.
there are series of problem in wii which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the wii repair guide that will help you a lot Click Here
Jul 08, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit board keeps telling me to step off and press (A) even though i am not stood on it
iv got the same problem too, iv resync it and nothing, wiped the wii clean and started again and nothing (mine went down just b 4 xmas and 'santa' got my boy the wii fit plus and he ant been able 2 play it yep) PLEASE PLEASE PLEASE some1 help
Jan 29, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit board keeps saying..please step off me and press A...this is when im not even on it..
the wii keeps saying step of me and press a when im not on it can anyone help its drivin my mad! please help
Nov 10, 2009 | Nintendo Wii Fit - Balance Board + Game...
I keep getting the message to "step off and press A" for the body test.
You need to step off the pad, wait until it tells you to step on. Then you push A to conduct the body test. If your pad is turned off push the button on the front of the wii fit pad then repeat the first steps i described.
Aug 03, 2009 | Nintendo Wii Fit for Wii
Wii Balance Board thinks I'm on it all the time!
Make sure of a couple of things and try again -
If you are on semi-shag carpet, try using the little foot extenders. They may not seem like much but they can help.
If you are on moderate to thick carpet, you may need a board to set the Wii Fit Balance Board on.
If you are on a wood floor, you can (but don't have to) remove the little foot extenders.
Another little gremlin can be in those silicone covers. If you have one, I'll bet that's the culprit. As nice as they are to keep the board clean, they can actually attach to the non-moving part of the scale (the bottom) to the moving (surface) part. Be sure that your silicone cover is not interfering with the normal movement of the board.
Finally, be sure that you are always using YOUR setting while exercising or it will not be calibrated correctly. Also be sure that when you start, you are not on the board when it calibrates for the first time after turning it on. If the weight on the board differs by about 5 lbs or more than what it thinks you weigh, it will pitch a little wii fit.
I hope you find this advise helpful. If not, though, please don't label this advise as "inappropriate". A "Thanks for Trying" would be just fine.
Thanks for using Fixya.
Mar 23, 2009 | Nintendo Wii Fit for Wii
Video Game Consoles & Games Logo
91 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
