Question about Ovens
Microvave control panel is locked and only shows 888. How to I unlock the control panel. I have tried plugging and unplugging it.
  • Ovens Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
I really wish you had provided a make and model number but.. here goes without a model number.
888 is what happens when you lose power on many microwaves. You simply push stop / cancel then you have to set the time by pushing CLOCK enter current time and CLOCK again. You should be able to use your microwave normally after doing this.
If this does not correct your 888 problem please respond with a make and model number so I can look up your model.
Thanks for choosing FixYa and Happy New Year,
Kelly
Posted on Jan 01, 2011
My Amana oven says loc when I try to ke
LOC often indicates that the control panel has been locked to prevent accidentally turning on (or off) the oven. This is useful when you clean the control panel (or have small children). Look on the appliance for a notation to press and hold a touch pad (or pair of them) to engage the control panel lock. On at least one model, you would press and hold Start for 3+ seconds to toggle the lock on and off.
On some models, this could indicate that the oven door is locked for cleaning. If the lock is flashing, then the switch is giving an incorrect door lock status. Check if the door is locked. For this situation, you can try unplugging (or turning off the circuit breaker) for 60 seconds or longer. If the message returns and the door is unlocked, then the lock assembly may need to be replaced.
I hope this helps. Please add a comment with the model number of your appliance and indicate if the oven door is locked or not, for more information.
Aug 06, 2017 | Amana Ovens
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
I cleaned my oven and can't get the door to unlock. It has been 12 hours since it finished cleaning. I have tried to cut the power at the electrical box and this did not work
Do a a hard reset of the control panel and locking mechanism. Unplug the cord, wait five minutes and then plug it in again. Try the door. You could also try to start another cleaning, interupt after 5 min hitting the clear/off button
Sep 10, 2011 | Kenmore 41389 Electric Double Oven
Oven door locked - display shows F5:E7
Hello there and thank you for choosing fixya
These codes normally show up during the cleaning cycle this is due to the extreem heat used during the self clean operation
Now to fix this is not too hard providing the sensor for the temperature has not been damaged due to the heat
Unplug the oven and leave it sit for 1 hour and do not touch there is a internal reset feature on these ovens that take 1 hour to reset once the hour is up plug in the oven and you may hear a audiable click sound or a buzz sound if so great then all you have to do is to press the cancel or off button then after 5 min attempt to unlock the door
if it does unlock and one of these error codes are still showing this means the the controle panel has suffered some damage and needs to be replace
I have seen brand new ovens have the controle panel fail after the first self clean operation because the parts inside of it fail due to the extreem heat ok?
Hope this helps
Best regards Michael
Apr 20, 2011 | Ovens
I used the self clean cycle and it has cooled off now getting error F5E1 and won't unlock? Please help. I use my oven almost daily!!
F5-E1 is a door lock error. Depending on the extent of the error, a hard reset may recycle the door lock and allow you to use the oven. Turn off power to the oven for 2 to 5 minutes and then turn the power back on. Give the oven about 2 to 3 minutes to possibly reset.
If the error code returns, there a few different problems you may have.
  1. The door latch mechanism could be broken or shorted
  2. The may be a pinched or shorted wire
  3. The Oven Control Unit may be bad
If further assistance is needed, please submit the brand and model # of your oven
Apr 15, 2011 | Ovens
Self clean lock
Hello there:
Normally every body gets this almost right by cutting the power but there is a trick to this it can be done in 2 different ways depending on the unit
First unplug the unit and wait 15 -30 seconds then plug it back in and wait for 15 to 30 seconds then unplug it again and repeat this step 1 more time then upon the final plug in wait for 5 min and then unlock as you normally would.
now on the newer units the trick is to let it stand unplugged for 1 hour to allow the internal reset device to reset the appliance then plug it back in and then wait 5 min and you should hear it automatically unlock the appliance or you cn simply unlock it as you normally would
BUT REMEMBER DO NOT TOUCH IT FOR THE 5 MINUTES AFTER THE PLUG IN STAGE OR YOU WILL HAVE TO DO IT ALL OVER AGAIN OK
Hope this is very helpful for you please keep me posted on how this is going there is still more that i can show you but i wanted to start with the basics ok?
Apr 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
MY OVEN IS LOCKED
unplug the oven wait 5 minutes and plug back in usually that resets the controll panel then it will unlock
Jan 21, 2010 | Maytag MEW5527B Electric Single Oven
GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
Dacor ECS136 Control panel just beeps but does not work
i am having that problem with my maytag one. the only thing i can do is unplug it and quickly press bake and set the temp and time length. mine says its locked though. i am trying to figure out how to unlock mine.
Oct 30, 2008 | Dacor ECS136 Epicure Stainless Steel...
Ovens Logo
43 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
