Question about Maytag Neptune MAH5500B Front Load Washer
We tried to start a load of wash today, but the drain hose was frozen. Water started coming out everywhere. We got the drain unfrozen, but the washer seems to still not be working. What do you think is wrong with it?
    President:
  • 2,468 Answers
The pump is probably split open from being frozen and the machine senses this and wont let it start
Posted on Jan 01, 2011
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
When start washing, filling water comes out from
This is most likely due to having the height of the drain hose too low in the drain pipe so the water siphons out as the machine tries to fill up. This will eventually lead to an F20 error displaying saying that the machine was not able to fill with enough water in the 6 minutes allowed by the on board controller in the Whirlpool.
The solution is to measure the height of the top of the arch of the drain hose or direct connecting point to a drain and make sure that his is at least 32 inches and no mort than 36 inches from the floor.
Oct 11, 2009 | Zanussi ZWF1430W Front Load Washer
How far should the drain hose be put into the waste pipe?I was painting behind the washer. I did not notice that I may have pulled out the drain hose, but during a wash cycle water started to spray...
Most have a hooked shape which can't be inserted too far. If yours is the flexible type it should be from 4 to 6 inches. If it's too far it can siphon the water out of the tub during the wash.
Sep 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Front-Loading Automatic Washing not draining
Change the brushes or start capacitor for the motor depending on which it takes.. The clothes are proberbly wet due to the motor not spinning the water out of them
Aug 25, 2009 | Kenmore Washing Machines
Water runs straight through to drain hose
Has the drain hose been moved?  The outlet of the hose needs to be higher than the top of the tub to prevent water siphoning out.
May 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2 water wont stop filling...over flowing everywhere.
Your level switch hose has come loose.first open the display panel to check in back of water level switch,and look for a hose that is not attached to the back of it.
Jun 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Wont drain error 3
check filter - try putting drain hose down at floor level and see if water runs out freely. if not, filter ius blocked. if water comes out freely, you may have a foreign object in drain pump. remove filterand see if you can see it. you will have water everywhere!!
Mar 26, 2007 | Hoover AAA160 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
