2004 Dodge Stratus Logo
Posted on Jan 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change out starter - 2004 Dodge Stratus
Anonymous
Level 2:
Scholar:
  • Expert 112 Answers
  • Posted on Jan 01, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
112
Questions
0
Helped
70653
Points
402
Starter - 4 Cylinder change out starter - 112139431
  1. Release hood latch and open hood.
  2. Disconnect and isolate the battery negative cable.
  3. Remove the air cleaner box.
  4. Remove the lower bolt.
  5. Remove the upper bolt and ground wire
Starter Removal - 4 Cylinder 112139432
  1. Remove starter.
  2. Disconnect solenoid wire connector from terminal
  3. Remove nut holding B+ wire to terminal.
  4. Disconnect solenoid and B+ wires from starter terminals.
2answers
Starter on my 91 ford ranger 4 wheel drive starts my pickup a couple time then it just spins have changed it 3 times now
Assuming the starter motor spins but doesn't engage to turn engine over to start you could have a bad starter drive which is part of the starter assembly or possibly damaged/missing teeth on flywheel ring gear. Depending on year and model vehicle, some starters you can replace just the starter drive otherwise you need to replace the whole starter. If you changed the starter look at the flywheel.
Blown starter fuse
you have a positive wire touching a ground in the starter or on the starter's wiring harness it could be in the positive battery cable
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tom_db3a51ff0ca57f20
Fusible link from the starter
DO ME A FAVOR CHECK THE BATTERY.
2answers
Starter makes a screeching noise sometimes just after the motor starts
Replace the starter before it ruins the flywheel. You have a worn out drive that applies to the flywheel. Flywheels are very very hard to change, in fact you can change 10 or 15 starters in the same time changing one flywheel
2helpful
2answers
Starter makes a grinding noise. and wont start changed starter and have the same problem. changed crank position senser and it worked for a while. changed it again but didnt fix the problem.
if the starter is making a grinding noise when you turn the key, it's one of several possiblites. 1. Bad Starter. 2. Bad flywheel. 3. You need starter shims that fit between the starter and the motor. Most starters will bolt straight up but sometimes the gears get too close so you need to shim them apart.
1helpful
Car will not start first thought it was the battery which turned out not to be true then found out it was the starter, starter has been replaced but car still will not start. It clicks twice and thats it...
did you change the solenoid with the starter or just the starter? if you changed both i'm not sure. if you just changed the starter and not the solenoid you should change the solenoid.
1helpful
My starter kicks out before the car starts how can i tell if its the starter or celinoid
It's most likely the "bendix drive" in the starter kicking out. It's the part that engages the starter to the flywheel. Changing a starter without changing the solenoid is like having a slice of bread without any butter. Change them as a pair. Hope this helps.
How to change starter selinoid
the starter selinoid is on the starter itself. normally a parts dealer will never seel you a starter selinoid individually but they will sell the starter with the selinoid. but you cant change the selinoid without changing the starter
I need to change my starter on a 1991 mercury sable
Starter are one of the easier mechanical engine parts to change.
1) DISCONNECT THE BATTERY.
2) Disconnect the electrical cable running to the solenoid on the starter.
3) Remove the two bolts holding the starter in place.
4) Pull the starter out.
To install another starter, do the above steps in reverse order in reverse.
3helpful
1998 Ford Windstar van will not start.
Ford starters have a solenoid that is a relay to the starter. I could not read the rest of the problem? Got changed ignition, starter and....
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
