Sound volume control - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
Control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Posted on Jan 01, 2011
What are the main cause of a choppy sound when you try to adjust volume
Dust accumulation on the inside of the volume control. With the amp off rapidly change the control from stop to stop several times or until the sound is no longer choppy. If this doesn't work then the volume control will need to be replaced. This trick works for a car radio too.
Jun 20, 2015 | Audio Players & Recorders
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Dec 04, 2013 | Computers & Internet
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
Computer detects speakers but no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 26, 2011 | Durabrand 5.1 Surround Sound Computer...
Cannot get volume on computer
also
Oct 22, 2011 | Audio Players & Recorders
What's your problem? my computer not read sound .i can not hear sound .what can i do ?
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers:
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume:
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check:
Sep 27, 2011 | HP (153147-001) Sound Card
What is referred by volume control?
hi when we say volume control its mean you are controlling the sound level volume of particular audio usually used a potentiometer (resistor ) to have a volume control in particular unit.hope this information help you good day.
Sep 07, 2011 | Computers & Internet
I have lost my sound on my desk top pc how do i retrive it bk again
maybe you selected the wrong sound driver. go to control panel. go to sounds, speech, and audio devices. go to sounds and audio devices. go to audio. sound playback, check the device and if diffrent change it and see if that works.
your main volume on all channels where droped. some applications can cause this to happen.
go to start. all programs. go to accessories. go to entertainment. volume control. ensure the volume is up on there. Then if it has it on your volume controll. click on speaker volume that is over top the main volume controll. and make sure your computer speakers didn't drop volume.
make sure the mute is not checked
Oct 25, 2010 | Computers & Internet
Volume
you might want to look into one of two options... either an external sound card, or a keyboard that has mltimedia buttons on it.
If you go with the former, the Audigy 2 NX external sound card might be want you are looking for. It's small and has volume controls right on the top. Granted, it is overkill if you just want simple volume control. However, if you don't have a high-end sound card already, it could be a nice addition to your desk..?
Jul 05, 2008 | Acer Aspire 3610 Notebook
I just bought a laptop do they have speakers built in? and if so where is the volume control I have a acer travelmate 200dx thanks Anne
volume control is normally located on the bottom right hand corner beside the clock, just double click on the speaker icon and you should be able to adjust the volume.
Mar 12, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
