Question about Danby DPAC7820 Air Conditioner
Continues running When I turn the unit off the cooling shuts down however the fan continues to run. The only way to shut the unit down is by unplugging.
    Novelist:
    Champion:
  • 230 Answers
There is probably a stuck fan relay on the circuit board. Have a technician take a look at it to confirm this and then replace it.
Posted on Jul 08, 2008
Air conditioner keeps working after unit is turned off ,the unit shows its off but the swing is still running and cold air ????
How long does it run, is it consistant? Some units are equipped with economizer software built into the controller/thermostat intended to capture the refrigeration effect as the internal pressures equalize. If equipped it works like this, thermostat shuts down the compressor a couple degrees above the set-point, the fan continues to run taking advantage of the continuing refrigeration provided after the compressor shuts down there is still pressure pent up the Freon continues to pass through the metering device to the low pressure of the cooling coil and continues to cool as the pressure bleeds down. If your machine does not have this feature you have a bad controller, call a tech.
Oct 31, 2017 | Heating & Cooling
Fan relay switch
The fan relay could be defective, especially if the fan continues to run after shutdown and drains the battery.
Nov 14, 2013 | 2007 Chrysler PT Cruiser Touring Hatchback
I have reno megane 04 my fan continues running when my car is not running i have had the air presureit has just happened again sensor replaced bu
Many cooling systems are designed to let the cooling fan continue to run even after shutting down the engine...however, this should only last for a minute or so...your owners manual may help. If the fan never stops when turned off this is probably a faulty resistor...may need a good mechanic to confirm which...Hope this helps.
Jul 09, 2012 | Cars & Trucks
Cooling fan continues to run after engine shut off.
The fan runs for a short time, after ignition off, to continue to cool the hot engine.
Dec 10, 2017 | 2005 Dodge Stratus
Qmark muh won't shut off
I believe these models have a thermal switch on or near the heating element that normally runs the fan until the element has cooled. Similar to your home furnace. If the fan never shuts off this switch is likely bad. IF it takes a long time to shut off then it may be out of calibration. In either case they are non repairable parts and have to be replaced. If the heater is in a high spot resulting in a high ambient temperature it may take a while for the fan to shut down.
Dec 20, 2011 | QMark MUH (0521) Compact Heater
The car runs great but when I shut off the engine the fan continues to run. How can I get it to shut off?
The fan is controlled by a thermostat, it will (should) shut off by itself after a few minutes, after the engine has cooled down a bit.
If it continues to run after about ten or fifteen minutes (i.e., it does not shut off at all, and will run the battery down if you leave it overnight), then most likely the fan relay is sticking on, and should be replaced. Less likely is that the fan thermostat is bad.
But if it turns off by itself after about five minutes, this is normal and desirable, it gets some of the excess heat out of the engine.
Aug 23, 2010 | Jeep Cherokee Cars & Trucks
The a/c unit cooling fan shuts down shortly after unit kicks on.
If a fan motor quits working during a cycle it usually means that the thermal protector is turning it off. If you had an amp meter on it, you would notice that it is exceeding the listing on the nameplate, Nine times out of ten this is irreversable, the motor needs to be changed. Sometimes if there are oil ports on the motor, you can add a few drops of zoom spout oil and that does the trick. But usually the motor is already damaged. Good luck.
Jul 11, 2009 | Carrier 38CKC036 Air Conditioner
When we shut off tv for the day the fan motor continues to run it does not turn off
the fan will continue to run after the power is shut down on a DLP television untill the set has cooled down . But it should shut off within a few minutes
May 23, 2009 | Televison & Video
Danby DPAC7820 Air Conditioner Logo
77 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
