Question about Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System
Cannot hear audio when connect dvd player to TV using analog audio cable
I can see the video clearly however cannot hear anything when i connect sony HDX 275 DVd player to TV (without connecting any of the speakers). This ia very simple connection and it should work, I am sure I must be doing something silly here...
1) How do I make sure that I am selecting analog audio on DVD player?
2) How do i make sure that TV input is correct in DVD player?
Thanks,
Kevin
  • jonscojo Aug 03, 2008
    I can get audio from the tv always except when playing a dvd, then I only get audio from the surround sound. I don't have the surround sound hooked up anymore so when I try to play a dvd I hear nothing.
  • junigilani Aug 07, 2008
    Hi, I purchased a dvi to hdmi cable to route my mac to my bravia 32" monitor. I also purchased an XTREMEHD switcher so I could have more than one input to my monitor. My hdtv cable box works (hdmi connection) and my Sony Bravia surround sound works (hdmi connection)
    Problem #1
    I cant get the surround sound to work when Im watching tv...that is, only the tv speakers work and the surround sound speakers dont...when Im watching a dvd, the surround sound speakers work and the lcd tv speakers are somehow disabled...is there a setting somewhere that can correct this? I've tried a few but cant figure it out...HELP!
    Problem#2
    My hdtv cable box and sony bravia surround sound/dvd player both work going through the hdmi switcher...but when I try to connect my Mac computer through the switcher (using a DVI to HDMI connector) or directly to my Sony Bravia LCD monitor, I get nothing...is there a setting for this on the Bravia TV that I'm missing???
    Pleeeeeeeeease Help!
I have the same problem,, the DVD and the TV are connected with a scart cable which is suppose to supply picture and sound, however only receive surrounding sounds and no voices when watching DVD;
Tv on its own works perfectly, I have lots of other cables supplied with the units, is the scart cable just the wrong one.
Thanks for any help
Posted on Sep 13, 2008
I think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
Posted on Aug 18, 2008
Connect tv audio input output receiver
Just make sure that you are using cables that are configured correctly physically and check to make sure that you are using the correct analog or digital signal necessary. Your audio settings need to be checked out and set accordingly. Check directions carefully.
Sep 03, 2017 | Sony DAV-DZ100 System
I have a new Denon AVR 1911 receiver all hooked up to my input devices and output thru a single HDMI cable to my Samsung LCD tv.... problem with getting audio from my DVD player: my DVD player is older...
Not likely that all those things are faulty.
The TV and DVD player make and model would be helpful to know. I would recommend running its BEST digital audio to the receiver and its stereo analog audio to the TV just in case you want to watch and hear the DVD in a lo-fi setting without the Denon. I generally advocate for connecting anything high-end (audio or video) ONLY to equipment that can use it or enhance it. Otherwise you may just be wasting expensive cable and adding unnecessary hops and connections that can fail.
Why do you want the audio to go from the DVD to the TV through the Denon? Are there no speakers on the Denon? Modern TV's have lots of inputs for the flexibility I recommend but rarely have decent audio or speakers.
May 06, 2011 | Audio Players & Recorders
My television does not have an audio output so i connected the rs 110 to my cable box and it works fine...however i also have a dvd player connected to the tv video input and for some reason i cannot hear...
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
  1. Look on the cable box to see if there is an option for AUDIO in (should be a pair of red and white RCA plugs)
  2. You want to run an RCA cable from the AUDIO OUT of the DVD player to the AUDIO IN of the cable box
  3. Then select the Auxillary input from the cable box and you should be able to hear the DVD
Alternatively you can run both DVD audio and video through the cable box
  1. Look for DVD IN on the cable box
  2. Connect the audio/video cables from the DVD player to the cable box
  3. To watch a DVD, switch to the DVD input on the cable box
Alternatively you can run the cable box through the DVD player
  1. There may be inputs for AUDIO and VIDEO in on the back of the DVD player
  2. You want to connect the outputs of the Cable box into the back of the DVD player
  3. You can then select the input on the DVD player to control whether you see/hear the cable or DVD
Mar 08, 2011 | Sennheiser RS 110 Consumer Headphones
I would like to connect the audio from my Comcast DVR via digital optical thru the TV/SAT IN optical on the receiver at the same time I have a composite connection via the TV RCA composite jacks. ( This...
I'm a little confused by your use of 'composite' with audio, as in "Does anyone know what would happen if I ran both composite audio and optical audio both to their respective TV/SAT IN input jacks on the STRDE935 ?". What is composite audio?
The manual claims on page 48 that you can't record digital audio out to the analog REC OUT jacks.
http://www.retrevo.com/s/Sony-STR-DE935-Receivers-review-manual/id/387dj981/t/1-2/
I say 'claims' because the engineers or manual writers clearly are not as creative as you are in trying to wring as much utility out if this unit as possible.
I can't find an answer but I would offer this - if you are recording anything though any AVR, as soon as you choose to monitor the audio the digital input is usually disabled.
And I would be curous to hear more about what you're doing and how you finally achieve it.
Dec 25, 2010 | Sony STR-DE935
How can I transfer the video from a Sony Handycam CCD-TR416 to CD or DVD
How to Transfer video from Sony Handycam CCD-TR416 to DVD - You need a DVD Recorder / Player, connected to your TV. Then using the audio / video cables from your camcorder, connect them to the TV as well. Turn your TV on so that you can watch the video out from your camcorder and then select the record button on your DVD Recorder / Player. Then you have a DVD that can be watched in any DVD Player or Computer with out any compression. This is how I transfer my camcorder tapes to DVD.
Aug 10, 2010 | Sony Handycam CCD-TR416 Camcorder
HOW TO SET UP SONY DVD PLAYER WITH HITACHI 42 LCD TV
Connect yellow video output on DVD player to yellow video input on TV using RCA cable. Connect white audio output on DVD player to white audio input on TV next to yellow. Connect red audio output on DVD (next to white) to red audio input on TV using RCA cable. Select on the TV using remote, the proper input for DVD player connection.
Aug 08, 2010 | Sony Televison & Video
I dont get the sound, can see pictures.
hey sajith,
check all the audio and video cable's connected to tv and dvd player.
you may have forgot the wire color's (audio and video) there would be one wire for video and two for audio. some times there would be a RF socket also. so, see the right sockets and connect to tv by interchanging wires.
Dec 29, 2009 | Sony DVP-NS575P DVD Player
I need help connecting sony dvp ns 300 to a jvc tv. I can't watch dvd at all, confused about the wiring where does it go?
The CD/DVD player has three output ports:
(i) Line out Video used to connect the yellow pin of composite cable.
(ii) S-video out use d to connect an S-video cable.
(iii) Component video out (red, blue, green) used to connect a component video cable.
So, in order to connect the CD/DVD player to the TV, the TV should have either of the corresponding input port on it.
However, the video quality transmitted by component video cable will be the best among the three.
So, you may connect the TV and the CD/DVD player using an appropriate cable.
All the above connections require an additional audio cable to transmit audio from the CD/DVD player to the TV.
In this case, you may use an RCA (red and white) audio cable to connect the "R and L" audio out port on the CD/DVD player to the corresponding "R and L" audio in port on the TV.
Performing all the above steps will help you get the DVD player work with the TV.
wish u good luck!!!!!!!!!!
Sep 17, 2009 | Sony DVP-NS300 DVD Player
Connecting a wii system to a sanyo DP26648 tv
It has to do with the type of input - Video2 and 3 are Component video inputs, requiring a 3- wire component video cable (Red,blue,green for video, red/white below for audio). Video 1 is for analog equipment (Yellow for the video, red and white for the audio). Unless your Wii comes with a component video out cable and jacks (same red blue green), you'll have to use video 1 for the Wii, and use Video 2 for the dvd. You'll need a component video (3-wire) cable for your dvd, which should have the jacks for it. You can use the present cable you're using for the dvd, but you'll have to change the connections on the back of the dvd to component video out, and you'll still need another 2-wire cable to connect the audio out on the dvd to the audio in on Video 2 on the tv.
Here's the manual for your tv - look on page 8 for these connections. the Wii will be an analog connnection, the dvd will be a digital connection.
http://www.sanyotv.com/DP26_32648%20Owners%20Manual.pdf
Hope this helps!
Mar 13, 2009 | Sanyo DP26648-R 26 in. LCD TV
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System Logo
339 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
