Question about Video Game Consoles & Games
It says cant read update from disk thats what is coming up
  • 492 Answers
It sounds to me like your 360 game has an update on the DVD and it can't attach it to your console. Try plugging in an ethernet cable, plug it into your modem or router and perform a system update, then try loading the disc again.
Posted on Jan 01, 2011
My ps3 wont read disk but turns on but i cant play games.....WHAT DO I NEED NEW ON MY PS3
You either need to send it in for a new disk drive, or there may be a new update you have not gotten, keeping you from reading disks (unlikely) you should send it in.
Jul 26, 2011 | Sony Playstation 3 (PS3) Console
I put a game in the xbox 360 to let it load up at the main xbox 360 screen where you can mess with your profile and the game loaded up and when I clicked the game to load up so i could play it it said I...
Make sure the disk is clean.
Reinsert and try again.
If it does not try to update again and it tries play the game but does not work and it is not because it cannot read the disk then go to the settings, hard drive and go to "System Cache" and delete.
This will delete all temporary files. Which means all small updates for games will be deleted. I reccomend doing this as it may be an error due to the update being stopped halfway through therefore being unfinished. So the xbox may recognise that the update has been installed but because it is unfinished then it may not be able to start the game.
If this still does not work try disconnecting from the internet as it will not ask for an update and you will be able to play the game without it. If this does not work and the game does not play it may be a problem with the disk.
First I would suggest playing the disk in a friend's xbox. If it still doesn't work, take the disk back to the shop and get it replaced.
Mar 02, 2011 | Video Game Consoles & Games
Hi my laptop wont read dvds cd's etc.. driver was updated it said it is fine. tryed trouble shooting in help but cant find any thing. when disk inserted a screen pops up saying to insert a disk.
now the most probable cause for this is the ribbon connector inside your laptop coming loose or malfunctioning,id check that first.If you can take it apart slowly and delicately-good luck!
Davey Snake!
Oct 20, 2010 | Toshiba Satellite A200-0ET00X Notebook
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
UPDATE REQUIRED CANT READ DISC
Well take off the front then make sure the disk drive is clean and void of gunk
May 08, 2010 | Microsoft Xbox Console
When i updated my PS3 for the new Call of Duty it stopped reading the disks. It worked fine b4 the upload but now it wont play any of d games i have. Whats d craic, how do i sort this
It might just be coincidence that your blu-ray drive has packed up at the same time as the update. Ring up Sony and tell them this and you could get a new console for free if your in the warranty.
Nov 12, 2009 | Sony Playstation 3 (PS3) Console
Wont read disk
i had that problem i took it back to the shop and swapped it now it works fine
Nov 29, 2008 | Microsoft 20GB Hard Drive for Xbox 360
Drive cant write any disc
If the unit was working ok and suddenly the unit stop to read the blank disk, the problem could be related to a dirty lector (need to clean) or unit firmware (need to be updated)
In that case you can update your firmware here:
http://drivers.softpedia.com/progDownload/Matsushita-DVD-RAM-UJ-840S-104-Download-14615.html
Remember
1) You have to use a blank "recordable disk" to allow your drive write a disk
2) Not all disks are compatible
3) Try differents brand
4) Clean your drive lector
5) Update your firmware
Oct 24, 2008 | HP Compaq nx6310 Notebook
When I try to burn a dvd.avi file to disk get i/o error cant read disk
can you update your firmware? Try a different disk and make sure its dvd r or rw..- or +. Ya....lol. Also download the latest divx and see if that will open the program.
Jun 12, 2008 | Computers & Internet
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
