Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Won't read blank DVD-R and now the door for the dvds won't open. Says there is no disc and pushing the open button doesn't work.
  • dorisw898 Jan 11, 2011
    Unplugging the unit for 40 mins. didn't help. I unplugged it for about 24 hours and it still didn't help. Before the dvd compartment didn't open I accidentally pushed the dubbing bottom on the front of the unit, and from that point on it didn't open the dvd door.
    Genius:
  • 1,126 Answers
It is possible that processor that could be locked up, do to a small power surge and if you leave it unplugged from the wall for 40 MIN., it will rest back to normal.
Posted on Jan 02, 2011
What do + and _ signs mean on blank dvds
- RecordNow! can record only to the same disc type
it records from. For example, you can record a
DVD only to a DVD+R or DVD+RW disc, and you
can record a CD only to a CD-R or a CD-RW disc.
you were using DVD-R, so it won't work.
hope this helps
Jun 18, 2012 | Verbatim Blank DVDR Discs/DVD R Media -...
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
My xbox won't read my dvds it tell me to open tray
you should try cleaning it with an actual dvd cleaning disc. if that doesn't work you may need to get a replacement drive and swap them out.
Mar 03, 2012 | Microsoft Xbox 360 Console
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
My Phillips Writable DVD driver is asking for a Blank DVD+RW9. I have Blank DVD+R Recordable discs.....why won't the DVD+R work? The Drive keeps requesting a blank disc.....they're all brand new.....HELP...
hello,,
you said you have p/n 280751-B21 , this is 16X DVDROM Read only -- this cannot do anything buit read DVDs.. it will not record anything, it is not capable..
if you give me the computer modsl and S/N , i iwll advise which CDRW/DVD youc an install in it (computer) to record and write CDs and DVDs
let me know
Dec 04, 2010 | HP (280751-B21) Internal DVD Drive
Cdrom doesnt recognise blank dvd. error message
Its only cd writer burner and can only that it can read dvd disc also. That is why its called combo. But burning blank dvd it can't. But if you want buy some dvdburner too.
Apr 19, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
