Question about Sony Playstation 3 (PS3) Console
80010514 I like many have just had the dreaded 80010514 error code appear on my ps3 what is the best form of action and is it still covered after 12 months
  • 3 Answers
OK I HAD THIS PROBLEM CALL SONY THEY TOLD ME IF U R STILL UNDER WARRANTY TAKE IT BACK THEYLL FIX IT FOR ABOUT $50 AND THEY GAVE IT BAK TO ME GOOOD AS NEW IM BACK AND GAMING IF U GOT PLAYSTATION NETWORK GTA IV MGS4 COD4 OR SVR08 MY PSN ID IS DMAN303 ADD ME
Posted on Jul 09, 2008
Go to this link as it has nice info on how to repair the problem. Its too much to list here. :)
http://www.ps3errorcodesfix.com/ps3-error-code-80010514
Sep 15, 2012 | Sony Playstation 3 (PS3) Console
Error cod 80010514 ps3
the PS3 error code 80010514 is related to an error with the Blu-Ray disk drive inside your PS3 console
Nov 03, 2010 | Sony Playstation 3 (PS3) Console
FIFA 11 game wont start (PS3) gives me error code 80010514. All other games work fine. Game works fine in brothers PS3. Never had this problem before. PS3 support says they have had a lot of calls with...
It's eiyther one of two problems:
The first is that FIFA 11 is screwed up due to an EA Sports programming glitch within the game - (see http://www.community.eu.playstation.com/t5/Technical-Help/FIFA-11-Error-80010514/m-p/11614173))
OR
The second is that your PS3 is dying and the laser won't read discs. Which gets progressively worse, or so i've read. - (see http://www.ps3blog.co.za/2008/04/10/ps3-error-80010514-explained/)
I'm getting the same error but my PS3 isn't yet 12 months old, so is going back to the store.
P*ssed that I can't play the new FIFA though!!!!
Oct 02, 2010 | Video Game Consoles & Games
Ps3 error code 80010514
This is alot of info but you wanted to know. :P hope it helps
Gamerevolver.com recently had an interesting article regarding the dreaded 80010514 error. I hope many of my loyal visitors never have to encounter it. Their is a known issue with the PS3, simply known as error 800010514 which doesn’t happen often but when it does, it’s darn right nasty.
The error in question is mainly seen within the first month of use, or to put it bluntly, it has the error right out of the box, however, we have seen this occur at almost a year into service as well.
“An error occurred during the start operation. 80010514′
Gamerevolver.com recently ran into the the dreaded 80010514 error shortly after installing a new game they had purchased off the PlayStation Store and decided to document it. Here is what the have to say…
Since this error occurred, we obviously contacted Sony Support. We were informed that the code is not common, and a simple reset of the system, and restoral of factory settings should do the trick. Unfortunately, after the restoral, the error still occurred.
The error code is actually one of two things, a) a faulty sector on the internal hard drive, or b) a faulty installation of software/firmware, both iterations actually coincide with eachother. If the hard drive suffers a faulty sector ( a section of damaged space on the drive that data may have been written to that no longer is readable), an installation may still be processed, and even work, but the error can cause some serious side effects, such as option b. If your PS3 has installed an item incorrectly, including firmware, it is in high risk of receiving this error.
Basically, what is occuring is the corruption of game disc recognition and execution. If you will notice, in 90% of all cases, the drive will still play DVD and even Blu Ray movies with no problems. When trying to start a game however, the title, sooner or later, will receive the error.
1) Ensure that your internet connection is stable. If you are using a wireless connection, make sure your signal is at least a solid 80%. If not, make the proper adjustments until it is.
2) Dust your machine regularly. Any PS3 owner will tell you that the Playstation 3 is a dust magnet. Just run a dry cloth over it every couple days, and you should be fine. This will help prevent heat issues and shorts that may occur.
3) When installing firmware and/or software, make sure you follow the instructions. Even if you have installed 6 versions prior, each one is different, and may require additional steps. Save yourself the headache and just follow them, it only takes a minute or so longer to do it right.
Lets sum it all up, the error is not hardware related and is caused due to corruption of firmware. Restoring you PS3 will not roll back the firmware, and unfortunately will not fix the issue 9 times out of 10. If you are receiving this error, contact Sony for a replacement unit. Again I hope none of my readers have to see the dreaded 80010514 error and by following Gamerevolver.com’s simple steps your bound to prolongue the life of your PS3 indefinitely.
(Update) Eurogamer.net contacted a SCE UK spokesperson which told them “”I’ve spoken to our Customer Services department and they aren’t aware of this issue with the PS3.” So take that as you will? Is the dreaded 80010514 just a myth? or an error that Sony is not aware of?
(Update 2) Try this before replacing Blu Ray drive (Last Resort)
Undertakerza updated a game, Warhawk and his system froze, got it rebooted it could no longer access any discs (cd, dvd, blu ray, games) he was ejecting and re inserting disks when I realized that the drive wasn’t making any noise and also … not spinning disks anymore they come out the exact same way he put them in.
Here is how he did it:
Ok so I’ve fixed my issue. I will run through what you will need to do to fix yours if you are having issues with the blu-ray drive and general PS3 system operations like the XMediaBar this is totally worth a shot … I doubt this will fix any other issue. If not then your blu-ray drive/ PS3 is probably dead and needs replacement via the method listed above or by sony.
If you can, I suggest you back up your PS3 first. The menu that you will access to can fully erase your PS3 if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3 firmware has a “recovery console”.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive.
However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory which is corrupted thus fixing the problem
UPDATE: With the new firmware 3.10 you may be able to report the error code directly to Sony via your PS3 console. Have a look here, please note that this has not been tested for this error code yet.
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
Got error code 80010514 after trying play COD online, screen froze now no other games will play
hi,
this error code (80010514) is indeed a hardware failure, to be more specific, the Blueray drive has failed and the system will not run like this. If you can still avail the warranty, then sent it back for replacement under warranty. I hope this may help you,
best regards,
kaybicks
Feb 27, 2010 | Sony Playstation 3 (PS3) Console
Error code 80010514
Unfortunately, from what I have read, it looks like you should call Sony. This is a hardware failure code and has nothing to do with firmware. Hopefully the system is still under warranty.
Jun 25, 2009 | Sony Playstation 3 (PS3) Console
My ps3 always write code error 80010514 and it freezes after 5min
you not really explaining why?
what are you doing that you are getting theerror code?
are you downloading somthing?
is it when you are playinga game?
when you turn it on dose it appear?
you need to explain....im waiting for a comment than i will help
Jun 24, 2009 | Sony Playstation 3 (PS3) Console
Disc reading problems
Gamerevolver.comrecently ran into the the dreaded 80010514 error shortly afterinstalling a new game they had purchased off the PlayStation Store anddecided to document it. Here is what the have to say…
Since this error occurred, we obviously contacted SonySupport. We were informed that the code is not common, and a simplereset of the system, and restoral of factory settings should do thetrick. Unfortunately, after the restoral, the error still occurred.
The error code is actually one of two things, a) afaulty sector on the internal hard drive, or b) a faulty installationof software/firmware, both iterations actually coincide with eachother.If the hard drive suffers a faulty sector ( a section of damaged spaceon the drive that data may have been written to that no longer isreadable), an installation may still be processed, and even work, butthe error can cause some serious side effects, such as option b. Ifyour PS3 has installed an item incorrectly, including firmware, it isin high risk of receiving this error.
Basically, what is occuring is the corruption of game discrecognition and execution. If you will notice, in 90% of all cases, thedrive will still play DVD and even Blu Ray movies with no problems.When trying to start a game however, the title, sooner or later, willreceive the error.
1) Ensure that your internet connection is stable.If you are using a wireless connection, make sure your signal is atleast a solid 80%. If not, make the proper adjustments until it is.
2) Dust your machine regularly. Any PS3 owner willtell you that the Playstation 3 is a dust magnet. Just run a dry clothover it every couple days, and you should be fine. This will helpprevent heat issues and shorts that may occur.
3) When installing firmware and/or software, makesure you follow the instructions. Even if you have installed 6 versionsprior, each one is different, and may require additional steps. Saveyourself the headache and just follow them, it only takes a minute orso longer to do it right.
Lets sum it all up, the error is not hardware related and is causeddue to corruption of firmware. Restoring you PS3 will not roll back thefirmware, and unfortunately will not fix the issue 9 times out of 10. If you are receiving this error, contact Sony for a replacement unit. Again I hope none of my readers have to see the dreaded 80010514 error and by following Gamerevolver.com’s simple steps your bound to prolongue the life of your PS3 indefinitely.
If u have access to another hard drive, try replacing the ps3 one with this one, if not, back to Sony it is.
Nov 19, 2008 | Sony Playstation 3 (PS3) Console
Erroe code 80010514
Hi mastergamer.
Someone else asked it here too:
http://www.fixya.com/support/t950015-error_code_80010514
The best diagnosis for now according to the link I posted in the above URL is that the drive has failed to function correctly ( maybe a bad laser or something) and needs to be sent in for repair.)
Aug 21, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
57 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
