Question about GE 50465 SurgePro 24Hour Timer with Single Outlet Surge
Setting the timer to turn off - GE 50465 SurgePro 24Hour Timer with Single Outlet Surge
  • 927 Answers
Set switch to timer on.
Rotate timer to correct time of day.
Push in pins for whenever you want the device to run.
Plug it in.
Posted on Jan 01, 2011
Outdoor lights timer: Intermatic HB851 photo timer with dial. How do I set it for dusk ON then off in 8 hrs.
Intermatic make HB51 timer.
If this is not your timer, then add a comment.
To set for ON at dusk, and off 8 hours later, rotate dial to the number 8.
Timer turns on automatically at dusk.
Timer set to 8 hours will start countdown when timer turns ON > and 8 hours later timer will turn off.
Make sure timer is turned away from lights so photo-eye doesn't receive feedback.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on again.
Feedback from lights will cause timer to reset the 8 hour countdown.
A car pulling in the driveway can cause feedback.
If the timer resets because of feedback, it begins the 8 hour countdown again, so the lights will not turn off until dawn.
You can test timer by putting black tape over photo eye, and then timer will turn on.
Set timer for 2 hours for example and then check if timer turned off 2 hours later.
If timer is not functioning correctly, then timer is defective.
Dec 18, 2010 | Woods Outdoor Lighting Timer
How do I get it to start at dusk and run for 4 hours
You posted under Intermatic make HB51 timer.
To set for ON at dusk, and off 4 hours later, rotate dial to the number 4.
Timer turns on automatically at dusk because timer has photo eye.
Timer set to 4 hours will start countdown when timer turns ON > and 4 hours later timer will turn off.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on.
Feedback from lights will cause timer to reset the 4 hour countdown.
A car pulling in driveway can cause feedback.
If timer resets because of feedback, it begins 4 hour countdown again, so lights will not turn off until much later than planned, or not turn off until dusk.
Dec 18, 2010 | Intermatic Outdoor Timer/Photo Control...
I want to use just the pm of the timer....for xmas lights....I see how the arrowis to be put on the 5 .....thats when i want them to come on....and 9 later in the evening....where do i put the arrow for...
You posted under The Woods/Coleman 2001 timer.
This is same as Westek TM14DOLB, Sylvania SA200 and similar to GE 57696.
If this is not your timer, add a comment with description and brand of timer.
Also see Woods timers and manuals to help identify your timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
This particular timer turns ON automatically at dusk.
And then you set the dial for other options as follows.
Dial set to ON > timer ON full time
Dial set to OFF > timer OFF
Dial set to 2 4 6 8 > timer turns OFF 2 4 6 8 hours after dusk
Dial set to Dawn-dusk > timer turns OFF at dawn.
Dec 12, 2010 | Woods Outdoor Lighting Timer
I baught a 3-outlet timer yardstake #15137. why does it blink on all settings except the on at all times?
Your yardstake timer has photo-eye that automatically turns lights on at dusk.
And then lights remain ON until set-time expires, or dawn arrives.
Timer automatically turns off at dawn, no matter which setting, unless timer dial set to ON
Photo-eye has to be turned away from outdoor lights or lights will blink.
That's because outdoor lights cause photo=eye to sense it's dawn, and timer turns OFF >>> a moment later photo-eye senses it's dark, and turns lights ON again.
Thus the timer turns ON-OFF.
Test this by putting black tape over photo-eye, or turning timer toward dark area. Timer should turn ON and follow set-time on dial.
Dec 11, 2010 | GE Hardware & Accessories
How do I set it and can I use it indoors?
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
To use timer outdoors.
Plug timer into wall.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
Program a timer
You posted under Paragon 2606 Panel-mount countdown timer.
If this is not your timer, add a comment.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
2600 series is mechanical interval timer.
26006-00 can handle 10 amp loads.
Interval timer is a countdown timer that keeps Load turned on for set amount of time.
You set the time by rotating dial
To start timer, Rotate dial from 1 minute to 30 minute.
Rotating dial turns on Load and begins countdown.
Timer turns OFF Load after set amount of time expires.
Nov 26, 2010 | Electric Paragon 2606-00 Timer
How do i set timer to turn lights off and on
If I understand correctly, you have Intermatic electro-mechanical timer that has a yellow clock dial on front
And you want to set the timer to turn lights on and off
And your wiring is correct and the manual override turns the lights on-and-off correctly
To set timer:
Pull dial back toward you. Rotate clock dial until current time lines up with silver pointer.
On other brands of timer, you rotate dial until current time lines up with an arrow or the word 'time' located on lower right of clock dial
Timer has on-off trippers that fit outer edge of dial.
Intermatic trippers are labeled ON and OFF
Other brands of timer have dark and light-colored trippers >> I think the dark trippers on some brands are OFF
Place 'off' tripper when you want timer to turn off
Place 'on' tripper when you want timer to turn on
Turn on electricity and expect timer to run for 20 years
Dial has to be re-set to current time after power outage
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Oct 20, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How do I set the hb51r so it turns on and off after 6 hours?
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk unless you set override feature shown below
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
From these instructions, you should push button until 6 displays. Timer will turn ON at dusk and turn OFF 6 hours later
If timer.
If you want timer to turn ON immediately and turn OFF 6 hours later, push button until 6. shows in display.
If timer does not display or does not operate correctly, then timer is suspect. Return timer for another one.
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
Setting
manual for HB51RC
See timer at Amazon
Timer turns on automatically at dusk + override lets timer run during daylight hours
F > Lights are OFF
O > Constant ON
GE 50465 SurgePro 24Hour Timer with Single Outlet Surge Logo
32 people viewed this question
Top GE Hardware & Accessories Experts
George Nalley
Level 1 Expert
Paul Bade
Gene Haynes
Are you a GE Hardware and Accessory Expert? Answer questions, earn points and help others
