Washer fills with water and then quits. It is not running or completing cycle.
  • 132 Answers
Check the belt is attached to motor
Posted on Jan 01, 2011
How to fix it!
change/check water lever switch
Jun 14, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
KENMORE DISHWASHER, WATER CONTINUES TO FILL AFTER WASHER IS SHUT OFF.
You're correct you have a faulty water inlet valve. At the end of the wash cycle the solenoid in the valve is not closing properly to not allow water to re-enter the tub. For further assistance with this repai
Jan 21, 2014 | Computers & Internet
Hot water keeps filling tub and does not quit
the washing machine is designed with a timer limit switch have the switch checked.
Oct 19, 2012 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Slow leak under unit cannot find problem. what specific should i look for?
It is most likely a hose connection from the pump to drain. What you could do is fill up the washer with cold water and color the water with food coloring let the washer rn thru a cycle. on its completion of the wash cycle and after it drains do not let it fill back up. Turn the water supply taps off and til the washer over on its front. With a tissue,(white), find the spot arond the connections where the color has dripped from. Repair that conection and with the washer back uprite run thru a complete cycle to test for leaks as well to purge the color out of the system. You either must do the later or run like h--l if the wife gets that color on her clothes. lol
Sep 28, 2010 | Kenmore 23822 Top Load Washer
When not in use, my washer begins to slowly fill with water.
you either have a very poor water pressure to the machine or the fill valve is not closing completely and will need to be replaced.
Mar 19, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
