Question about Microsoft Xbox 360 Console
My sons xbox 360 is sayin ...cant red update from disk . there is a status code and it is 22fb-2080-2200-0700-c000-0059 we need help..cannot fix...what do we do???
  • Aaron Busch
    Aaron Busch Jan 01, 2011
    You're reading the wrong error code. That seems more like a serial number. Can you give me the error message or error code that you get?
SOURCE: I GET A MESSAGE STATUS
Holding the sync button on the console as per other forums didnt work initially, so did it loads of times:
Had the disc loaded that caused problem, held sync button on the console and powered off and on still holding the button on. Powered off each time the error screen came back up while all the time holding the sync button on the sixth attempt it went past error screen and up to dashboard.
I went to load disc again and it asked me for update again so chanced it, this time it extracted update ok and then rebooted to dashboard ok.
Console now running fine, oh and Assassins Creed was the game that caused the initial update error, and Assassins Creed was the disc that I used in the multiple reboots which eventually cleared update fault.
Hope this helps as no other info on web that I could find.
Posted on Feb 19, 2011
SOURCE: i have the new xbox
I can fix this i am a xbox 360 repair man and i can fix and micro soft can not even fix this look me up on ebay 251-279-7150 david
Posted on Mar 20, 2011
  • 8 Answers
SOURCE: 22FB-3151-b200-0700-c000-0013 Put in an xbox mag
1. Anote second hex data 22FB-3151-b200-0700-c000-0013 and go to http://easycalculation.com/hex-converter.php
2.
Convert it to decimal and get the update number:
Hex:
3151 - Decimal: 12625 Update
3. Go to http://dl.console.se/index.php?dir=Xbox360/uppdateringar/ and seek the correct update. Download it.
if not try to locate it on google)
4. Extract $Systemupdate and put it into root of a pendrive formatted in fat32 or a CD
5. Turn off the console and plug the pendrive or insert the CD
6. Turn on the console and wait
7. Enjoy!
Posted on Aug 23, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: xbox 360 update error is this: status code: 22FB -
Hello
There are two ways around this.Both you will need a pc.
Log into x box live and find system updates.Download and save to my documents or desktop,somewhere you can find them easy.
1 use a usb flash drive to download too.Then upload it into the x box.
2 Or burn the update to a cd or dvd and run it on the x box .
Posted on Sep 27, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: my xbox 360 showed error code
Hello
Use a flash drive or a usb cable,Download the update from x box live onto your pc.Use a winzip program such as winrar or winzip to compress it.
Save update to your documents.
Once done transfer update to a flash drive and connect it to your x box and extract it.
Or using a usb cable connected to the x box from the pc,transfer the data to the x box.
Posted on Oct 11, 2011
My xbox 360 was updating and it stoped and froze, its says my system update failed status code 3151-351f-b380-0402-c000-0001
According to the Xbox Support page, you should contact Microsoft about this error. http://support.xbox.com/en-US/contact-us
Other than that, I would suggest trying to update using different methods. If the problem occurred while updating from Live, try putting the update on a disk or flash drive. Here is a link to the update page where you can find the downloads for disk and flash drive. http://support.xbox.com/en-US/xbox-360/how-to/update-xbox-360/system-updates
Good luck.
Sep 29, 2011 | Microsoft Xbox 360 Console
Xbox 360 update error is this: status code: 22FB - 351F - B900 - 0402 - C000 - 0001 just wont update
Hello
Sep 27, 2011 | Microsoft Xbox 360 Console
Can anyone help me how to fix my xbox360 with this status code: 22FB-351F-B800-0F00-C000-003
Hello
The only part of this code i recognize is the c000-003 Which is a power supply error code.
Possible your power supply is faulty.
First try a different outlet to plug x box into.
Sep 20, 2011 | Microsoft Xbox 360 Console
22FB-3151-b200-0700-c000-0013 Put in an xbox mag disk and it screwed up the xbox and gave me this status code
2.
Hex:
7. Enjoy!
Apr 22, 2011 | Microsoft Xbox 360 Console
I put a game in the xbox 360 to let it load up at the main xbox 360 screen where you can mess with your profile and the game loaded up and when I clicked the game to load up so i could play it it said I...
Make sure the disk is clean.
Reinsert and try again.
If it does not try to update again and it tries play the game but does not work and it is not because it cannot read the disk then go to the settings, hard drive and go to "System Cache" and delete.
This will delete all temporary files. Which means all small updates for games will be deleted. I reccomend doing this as it may be an error due to the update being stopped halfway through therefore being unfinished. So the xbox may recognise that the update has been installed but because it is unfinished then it may not be able to start the game.
If this still does not work try disconnecting from the internet as it will not ask for an update and you will be able to play the game without it. If this does not work and the game does not play it may be a problem with the disk.
First I would suggest playing the disk in a friend's xbox. If it still doesn't work, take the disk back to the shop and get it replaced.
Mar 02, 2011 | Video Game Consoles & Games
When i put my games in my xbox360 is say u need help vist www.xbox .com when i go to it what do i do
Hi.
That means that you need to update the XBox. The best way to upgrade is through XBox live.
Information about how to update your console software is available on the Xbox support website:
support.xbox.com/pages/xbox-360/how-to/update-xbox-360/system-updates.aspx
If you need further assistance, go to the xbox.com forums at forums.xbox.com for community assistance, or contact Xbox Customer Support using the details at www.xbox.com/contactinfo
Jan 11, 2011 | Microsoft Xbox 360 Console
Cant stream avi files anymore to xbox360
There may be an update that you require, either that or your poor lil Xbox has contracted an illness, i would try and leave it off for a while, then try again. And also, go through your sons xbox and compare it with what you have on your settings. If anything is different, that may be your problem!
Feb 23, 2010 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
187 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
