Question about Bosch 4000 - 07 Electric Table Saws
My table saw runs in reverse when turned on it is a 4000
  • 154 Answers
This is unfortunatly a fairly common problem with the Bosch saws, the field coil has failed and needs to be replaced. If the saw is less than a year old it will be under warranty, if not this repair is still worth doing as it is alot less than a new saw. This repair is faily difficult and should be done by a Bosch service center, find one in your area and they will be able to help you.
Posted on Jan 07, 2011
Bosh 4000 table saw runs backward and at low speed
I've worked on some table saws with problems like you describe, a couple needed a new speed control unit (Bosch PN 2610997306) in the motor. If all the wiring to and inside the motor is OK and not shorting out anywhere, that's the next part you should look at.
Jul 10, 2012 | Bosch 4000 10IN Table Saw
Bosch 4000
The speed control on your table saw works by sensing what's going on in the field. If you replaced the speed control circuit board and the motor still runs out of control, the next item to replace is the field.
Feb 10, 2012 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 table saw run backward and slowly
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
Apr 28, 2011 | Bosch 4000 - 07 Electric Table Saws
My table saw was overheated and now will only run in reverse?
sounds like you have a major electrical problem possibly, when it overheated did you get a burning smell from it and if so it could have burnt up the field and or armature. If you are comfortable with disassembly let me know and I will try and help
Aug 28, 2010 | Bosch 4000 - 07 Electric Table Saws
I can't get the rip fence on my bosch 4000 table saw to square up to the table. the fence is parallel to the blade but when locked down it tilts a hair towards the blade at the top. and it doesn't seem...
hi ,
this is the link to the bosch manual for your table saw , it has the assembly instructions ( just reverse them ) and full details of the alignment proceadures required to true the blade/guides and fences up .
http://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D/t10/0000000/r00160v-1.pdf
hope this helps
Jan 17, 2010 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 table saw runs too fast
Change the pulley on the motor to a smaller diameter to reduce the speed.
Sep 18, 2009 | Bosch 4000 - 07 Electric Table Saws
My bosch table saw runs slowly backwards what part do i replace
Replace the field coil. I'm going to bet its a Model 4000. I have done about 100 of these saws in the last couple of years and my customers always complain of the same problem, "the saw was running backwards"
Change the armature back bearing while you have it apart, they always seize eventually.
Jun 23, 2009 | Bosch 4000 - 07 Electric Table Saws
My saw runs backwards too!
Try to put the blade in the other way. then see if it works.
Dec 31, 2008 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 tablesaw suddenly ran backwards and died
I had a customer bring me a saw with this same problem. All components tested OK on my growler. I went on a limb since the speed control and the armature tested OK. I replaced the feild since to me it seemed to be the only component that could cause the motor to run in reverse. Tool now works properly and have had no more problems with the tool.
Dec 02, 2008 | Bosch Electric Table Saws
Bosh 4000 table saw , using dado blades.
no good solution for that problem. dado blades vibrate and cause the knob to turn. possibly a clamp on the knob to keep it in place.
tom
Nov 25, 2008 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 - 07 Electric Table Saws Logo
202 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
