Question about NEC PlasmaSync PX-61XM1A 61 in. Television
I have an NEC PlasmaSync PX-61XM1A tv that i am unable to use because te screen keeps blacking out the top half completely so I have only the bottom half of the screen to watch. Today I tried to turn it on and the standby light is blinking red/green and it will not turn on. I disconnected it from power and tried again with the same results. Help . . .
SOURCE: nec px-42vp4a that turns off
Hello. I have the same issue with my px-42vp4a. Did you figure out the problem. Email me with you did. paulh77p@excite.com. Thank you. Paul
Posted on Mar 22, 2008
SOURCE: Problem with NEC PlasmaSync 42MP1 42 inch - goes to standby w/no picture
Has anyone figured this issue out? Im really hurting without a tv,
Posted on Nov 18, 2008
  • 9 Answers
SOURCE: i can viwe only small space in screen before it was half screen
I can guarantee to fix this tv for $400-900. I have all good boards and know the procedure to determine which board is bad.
Posted on Nov 22, 2008
  • 118 Answers
SOURCE: nec plasmasync 50MP2
Lol, I'm not a Guru but I am a Wiz, so I can help. Usually, those lines you see, are from the burning of a channel. It's when the plasma gases inside of the screen stick to the screen and don't come off, it's permanent. Unless your T.V. type has on the menu a Screen Burn Protection like a 50 inch Samsung I have. The only reason it burns is because bright white lines in front of a dark background. Usually HD channels have small icons so they don't stick in the screen, so unless it's under warranty, you can take it back, but if not, then sorry. You can't do anything with no warranty or receipt.
Posted on Jan 31, 2009
pabloloco
  • 2335 Answers
SOURCE: NEC PX-42VM3A 42" Power problem
I have read that this has been fixed with little more than a hard reset. This means just unplug your set for 10 minutes or so and let all the power seep out of the boards and capacitors, then plug it back it.
If that didn't fix it, your unit needs servicing. If you are handy here are some troubleshooting steps:
Check the fuse at Y-Sustainer pcb.
If blown do not replace. Look instead at scan converter boards. They are connected between y-sus & plugs from display (left side with face down, back open). Look for signs of 'burning' at upper and lower long boards. If any imperfections are found, replace all three boards: Y-sus, up & low scan.
If fuse was okay, check power supply for bloated capacitors (big board in middle of set).
I hope that helps.
Posted on Apr 19, 2010
NEC PlasmaSync PX-61XM1A Refreshes every 5 minutes when connected to PC
Look for settings of that port in PC as well as in TV. Is there a chance of some virus?
Aug 15, 2012 | NEC PlasmaSync PX-61XM1A 61 in. Television
No picture, LED blinking Green and red
u need a knew tube in ur tv as my sisters was doing the same
Apr 09, 2012 | NEC PlasmaSync PX-61XM1A 61 in. Television
Metade tela preta metade branca desliga com sinal de video sem sinal comtinua ligada -nec px-42vm5a
Hello
From your description, I can't understand the problem of your TV well. "Half white half black screen with video signals"; you describes what? Please give me more details about the fault, as clear as you can, so that I can help you. Send these details to me by Fixya. OK.
May 16, 2011 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
The color has changed so that the picture contains only blues and greens and no red or yellow shades.
Your TV's red pixels are not firing.It has nothing to do with your settings or something you did.
Only service centers can handle this job .
Mar 09, 2011 | NEC PlasmaSync PX-61XM1A 61 in. Television
Intermittent lower screen
please give me more idea..lowering down screen??or a upper partial of the screen turns black and the lower portion only have picture?
Apr 27, 2010 | NEC PlasmaSync PX-61XM1A 61 in. Television
Black line in the middle of the screen
check for vertical ic it is faulty, replace and try again
May 23, 2009 | NEC PlasmaSync PX-61XM1A 61 in. Television
Plasma shows half screen
Have a technician come and replace the display drivers or buffers boards they are some times called.
May 15, 2009 | NEC PlasmaSync PX-61XM1A 61 in. Television
Black Square in bottom half middle of screen
It sounds like your panel is going out and time for a new TV
Nov 30, 2017 | NEC PlasmaSync 50MP1 50 in. Television
Not switching on
My NEC PlasmaSync did the same thing.  It's caused by not using a power filter on your AC input.  To reset your TV, turn off the power button on the bottom until no lights are flashing.  Then hold down the "Input Select" button while holding down the "power" button.  The tv should then reset.
Sep 04, 2007 | NEC PlasmaSync PX-61XM1A 61 in. Television
NEC PlasmaSync PX-61XM1A 61 in. Television Logo
88 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
