Question about Gaggia Classic Espresso Machine
Won't prime. I've run a full tank thru the steam wand and it still will not put water thru the basket
    President:
  • 1,618 Answers
Remove the screw and screen then try to run water through without the portafilter in place, if water flows, check the holes in the screen they might be blocked, put the screen on the stove or other open flame to clean, coffee will burn before the metal does. Use plies and cool screen then reassemble and try without portafilter, if that works then change grind to something coarser. If that does not work, remove screen and then the 2 allen wrench screws and check the spring and valve seat above the diffuser, make sure it is not blocked, reassemble and try to run water through.
Posted on Jan 05, 2011
Coffe does not come out, it starts sounding that it will then it stops
If you remove the porta filter, will water come out when you turn on the pump? If so, your porta filter is clogged and soaking it in white venigar will unclog it. To keep it from clogging, after each use, put it back on the machine and run hot water thru it until the water runs clear. (Remove grounds first)
Does water come out the steam wand?
When was the last time you ran a cleaner thru it? The Saeco de scaler cleaner is designed specifically for your machine. Purchase from Amazon for about $10.00 and use every six months.
if it still won't work,melt me know.
Feb 28, 2015 | Saeco VIA Venezia
I have a Saeco Incanto classic, the low water light is on, tank is full, and I have steam coming from the steam wand.
try descaling the machine it could be that the water level switch is clogged with water calcium and not lifting when water is added, or it is defective and needs replacement. I hope this was helpful.
Oct 22, 2014 | Saeco Incanto Classic Espresso Machine
Type: sup 015 st no water passes during rinse or
First, check / remove the water filter in the tank, next try to run hot water thru the wand, not steam but water, this should prime the system, then turn off and back on, that should do the trick, unless you have a bad pump. Good Luck!
Jun 27, 2010 | Saeco Stratos Coffee Maker, Espresso...
Just out of the box, the sirena espresso maker doesn't heat and buttons don't flash
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 15, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
My sirena does not work
anytime the water runs out and you need to refill the tank, you need to bleed the line so to speak. Take an empty cup and put it under the wand and open the knob of the steam wand until the blue light stops flashing
Feb 13, 2009 | Saeco Starbucks Sirena Espresso Machine
Via Veneto will not prime
Yes, unfortunately the Via Veneto is a difficult machine to prime, however, I have a simple way to prime the pump if you run into this problem. Simply remove the water tank, fill a clean turkey baster with water, open the steam valve fully then mate the baster tip with the water tank flow valve on the espresso machine. Wrap a towel or paper towel around the flow valve/baster tip then inject the water (agressively, but not forcefully). It's works for me every time.
Sep 18, 2008 | Saeco VIA Veneto Espresso & Coffee Maker
Blinking red water light on SAECO ITALIA with full tank of water
Your tank may be full but water is not getting into the system. The only way for the red light to go away is to have water come out of the other end...either the coffee spouts or the steam wand. The word they use for this is "pump priming". Thus, either the motor is not sucking water in or there is blockage. Unless water gets out to the other side, the red light will stay on. Before getting dirty with the system, check the tip of the steam wand...if old milk is blocking that end. You will know this is the case when you turn the steam knob counter clockwise to release water but you only hear a semi-startup on the motor and then abruptly stops while the steam knob simultaneously pops out a little bit. It indicates a "blowback"...that there is blockage at one end of the pipe (ie steam wand). Get the residue out by dipping the wand in a tall glass of hot water...wait for a few minutes and blow it out with using the steam knob. Should be ok after that.--Mabada1
Jun 26, 2008 | Saeco Easy Espresso Machine
Gaggia Classic Espresso Machine Logo
153 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
