Question about LG Heating & Cooling
Dear sir i have an A12AW1 art cool when i use the airco in the winter outsite temp -10 °C the airco somethime stops althow the roomtemperature is not reached. The airco is also outside frozen. when he is working the wind that came outside the inner device is warm but not very very hot. It's a device on R134 a. is that normal.I have another question, when there is to litle R134 a on the device will the airco give a signal or how can i recognice the default. Sorry for my englisch.
    New Friend:
  • 117 Answers
You should replaced your defrost board .
Posted on May 26, 2017
  • 1,653 Answers
Not sure the specs of 134. But, at 20 to 30 degrees Fahrenheit your heat pump is not going to be working very efficiently. Now, the ice on the coil is another story. Possibly your defrost is not working BUT, you don't have backup heat anyways. Yes, you should have a low pressure error code, I don't think it's a refrigerant issue.
  • 18 Answers
SOURCE: Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Posted on Dec 11, 2008
  • 127 Answers
SOURCE: ac not blowing cold after outside temp reaches 98 degrees
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Posted on Jun 29, 2009
  • 70 Answers
SOURCE: Compressor ?
Sounds like you are over heating the compressor, try cleaning the out door unit coil. Take a hose and blow water through it, be carefull not to bend the fins.
Posted on Jul 17, 2010
  • 1400 Answers
SOURCE: Problem with the Rinnai RHFE-1004FAP
There should be a condensation line connected to the flue running into a pump or floor drain.or possibly a internal heater to disapate it.
Beacause the heater reuses the gas there is alot of moisture in natural gas,thay needs to be drained from the flue.
Sounds like this condensate line is either clogged or frozen or both.Yes your going to need to thaw the flue out.Before you do this turn off all gas and electric to the heater,we do not want it to start.
A hair dryer may do the trick,to help thaw the ice off.If you can locate the drain line for the flue and thaw it out and clean it out.Check that all filters are clean and in place before starting up.
Also check outside that nothing is driping onto the flue from the roof or a tree.
I found a link with your owners manual.
Hope ive helped.
Posted on Dec 14, 2010
Testimonial: "GREAT ANSWER --- used a hair dryer on the outside flue (after it had been in sun a few hours (luckily flue is on south side of house) Started by turned gas/elec off, then chip'd most of ice off, then gave it high heat till water started drip'g out of flue (~2-3 mins), then went back inside and turned gas/elec back on and started heater --after repeating this process a few times (3?) heater stayed on and we had heat !!!! Sorry for not writing sooner.... but want to let you know that we had the 'opportunity' to reapply your solution twice more during last winter - worked great both times !! "
  • 30 Answers
SOURCE: master cool not cooling. Outside
I would bet that the problem lies in what you said about the pad. It needs to be well-soaked for the evaporative effect of the unit to do its job.
You give no model, but if you disassemble the unit (only the top panel) at the water distribution tube and expose it you can see what's going on. Water flow will be minimal.
The tube disconnects from the water supply tube at one end.
Disconnect it and, carefully since it's plastic, clear debris out of the distributor.
If it's like mine, it will have a fair amount of scale built-up in it. Once clear, re-assemble and start the unit.
Posted on Jun 28, 2011
Why is my airco not cooling?
I believe that error code refers to a defective Indoor Coil Temperature Sensor (Thermistor); probably an "open" or "shorted" condition.
Jul 08, 2014 | Heating & Cooling
Hi have problem with canadian spa (balboa mrspa1) control panel digital reading when turned on goes to OH,circulation pump will not run
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
Hope this helps.
Mar 30, 2011 | Balboa Instruments Duplex Digital Panel 2...
At what outdoor temp does the unit stop heating. model lsn186he
Operating Range Cooling Operating Range: 23° - 115°F Cooling Operating Range with Low Ambient Kit: 0° - 115°F Heating Operating Range: 14° - 75°F Cooling Thermostat Range: 64° - 86°F Heating Thermostat Range: 60° - 86°F
Jan 08, 2011 | LG Heating & Cooling
Lg split system ch 46 error? help!!!
Ch-46Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor
Jan 07, 2011 | LG Art Cool LA181CNW Split System Air...
Nw my lg Aircon appear CH 46 how to solve this problem
Nov 18, 2010 | LG Art Cool LA181CNW Split System Air...
Air condition jsut 10 month old ... not keeping up whith cooling
If it's only 92° outside and the unit won't cool the house, then the unit is either to small or it's low on refrigerant. They are designed to cool a house with outdoor temperatures up to 115° to 120°.Usually you need one ton a/c for every 400 square feet of house, but, you have to take into account for average outdoor temperature and humidity, windows, doors, especially sliding glass or patio doors and which side of the house they are on, insulation in walls and attic.
The air leaving your duct work going into the rooms should be about 20° lower than the room temperature, if you have a 80° room then the air leaving the duct should be around 60°. if it is then the unit is probably to small if, everything is working properly.
Jun 07, 2010 | Goodman CLQ36AR49 Air Conditioner
Electric Radiator Fan Does Not Come On
Chevy dealer says will not come on until temperature reaches 219 f
May 16, 2010 | 2007 Chevrolet Silverado 1500 2WD
LG Art Cool Error Code CA
Compressor discharge sensor fault. Disconnect from PCB measure resistance 237 kOhm at 20°C, 168 kOhm at 30C. Replace sensor.
May 04, 2010 | LG Art Cool LA181CNW Split System Air...
I have a 1999 Volkswagon Passat. The air conditioner works great at night or when the outside air temp is below 80°; it will put out 55° air. But during the day it will only put out 10°...
check to see if you have a cabin air filter and if it is dirty have it replaced at a local auto shop.. if that isnt the problem and the freon level is correct then you will have to live with it.. a/c are concidered effiectient if they cool 20* below ambiant tempature.. personally i would say have the freon level/quality checked again
Aug 03, 2009 | 1999 Volkswagen Passat
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
