Question about Black & Decker V4810 DustBuster Bagless Handheld Vacuum
Are there batteries packs available for this model?
I have a scunci rechargeable wet and dry vac. Model 52069. I plugged it in to charge green light turns on. Couple hours later I unplug it and push the button nothing. Need instructions or manual.
Most likely the rechargeable battery needs to be replaced.
Unfortunately, I haven't been able to find a battery pack listed anywhere. You'll probably have to have a company like Batteries + Bulbs (In the USA) take it apart and replace the battery pack.
Nov 11, 2016 | Scunci Vacuums
Were to find replacement battery pack
I would suspect that they would only be available thru DIRT DEVIL
Jan 03, 2016 | Dirt Devil BD10165 Gator Bagless Hand Held...
How can I get a battery pack for an unidentified vacuum cleaner?
Use the identification off the battery pack it self to find a replacement. Just google it, part number or model.
Jan 03, 2016 | Vacuums
How does one open the battery case?
Hi Russell, it's Jack at Dyson.
The battery pack for our cordless vacuums is manufactured as a sealed assembly, and is not designed to be opened or dismantled - attempting to do so could cause damage. Additionally as the battery pack is supplied to us as a complete assembly, we do not have individual internal components available to order.
We would strongly encourage to you contact us directly so we can take some further details about the issue - talking you through some simple diagnostic checks should help us confirm if the fault lies with the battery pack, charger assembly or the control software in the main body of your Dyson cordless vacuum.
When you have your machine easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Mar 18, 2015 | Dyson DC39 Animal Vacuum
Red light flashing very fast and not charging fully
How long is it charging until the light goes from flashing red (no charge) to yellow to finally green (full charge) ? If it's not at least 2 hours, sorry I don't have my Roomba papers available, so I'm guesstimating here, it's not getting a full charge. If you can put a voltmeter on the " fully charged" battery pack, that might tell you if the charger is the problem. Clean off the metal contacts where Roomba meets the two metal contacts on the charger. Also just because a battery pack or set is new doesn't mean it's functional. I had a new Apple battery for my laptop that didn't work when I replaced an older one.
Sep 26, 2014 | iRobot Roomba 530 Robotic Vacuum
My Roomba Model 440 runs for about 2 minutes and stops. I can start it up again after which it repeats stopping after not quite 2 minutes. It is perfectly clean and charged. What is the problem?
Most likely your NiCad battery is at the end of it's life and needs replacement. The packs in Roombas are made up of a group of individual cells and what often happens as they age is that a single cell will fail, causing the entire pack to provide less than usable voltage. The Roomba will attempt to operate and then sensing low voltage, it will shut down.
To prevent reduced battery life in the future with your new pack, always keep your Roomba charged as storing a NiCad pack in a discharged state will cause the build up of salts within the pack, damaging the cells.
Replacement is simple and packs are around $40 bucks online, all you need is a small Phillips screwdriver and about 5 minutes.
Oct 02, 2013 | Roomba 440 Cordless Robot Vacuum Cleaner...
Need battery for fhv1200
Black and Decker, does not provide a replacement battery for your model. It is supposed to last 4 years. I have been scouring the web in order to find a suitable replacement but can not find anything. Is there a model number on your battery pack that you can provide for further research?
Sep 03, 2013 | Black & Decker Black Decker FHV1200...
I need a black and decker dustbuster manual to know what kind of batteries to buy. I recently got this dustbuster at a garage sale. The charge/wall mount says it is a 9.6volt FVE9610 Type 1. Help? Joan...
I have bad news. That part is no longer available; check out the info here:
http://www.ereplacementparts.com/black-and-decker-fve9610-dustbuster-parts-c-4167_8887_8911.html
I actually have exactly this kind of dustbuster, and I was able to renew the battery pack, but I had to do it by using eight individual cells and soldering them together. The size of cell (I think it's called a sub-c) is not common to consumers, but is fairly common to battery pack manufacturers. Quite honestly, your dustbuster with no battery is worthless, even when it was available, the pack was $46.46 as a spare - probably more than the thing is worth. Buy a new one from wal mart! If you really, really want to look at getting a new pack for this one, then your only option is to find a specialist battery store (I know there's one in my city) that can 'remanufacture' them. Basically, they take the old pack, and rip out the old cells, and put in new ones. They have the special equipment to weld the connections without frying the cells too, and they have access to Sub-C cells, of course. It'll be expensive. Good luck, you're gonna need it. Sell it at a garage sale; it looks nice.
Feb 05, 2011 | Vacuums
Battery Pack for the Eureka Boss Model 93B
tHE 96 F IS ALMOST THE EXACT SAME AS THE MODEL YOU HAVE. THEY HAVE THE SAME POWER TO THEM THE BATTERIES WERE JUST DIFFERENT
Jul 18, 2009 | Vacuums
I am looking for a battery for a westinghouse model wst1600a
I too was looking for a battery for the WST1500a. I took the charger and a defective battery pack to BATTERIES PLUS. They rebuilt the pack with new fresh and fully charaged batteries in a short time. The result was good and better then a new battery pack that had been sitting on a store's shelf for 5 years. The advantage is that they are new batteries with a correct charage. The cost was about 75 dollars.
BATTERIES PLUS is a chain and are available in many large cities.
If you need a new "case" for the batteries so you can rebuild the pack, they do have some "packs" on E-Bay listed under BP1600. It's always a "hit and miss" on E-Bay. The problem is that the current vendor lists the BP1600 pack as a Black & Decker part and doesn't know exactly what he is selling. There is no picture of this on the current listing which isn't good.
Feb 19, 2009 | Westinghouse WST1600 Upright Vacuum
Black & Decker V4810 DustBuster Bagless Handheld Vacuum Logo
50 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Greg Cann
Greg Cann
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
