Hi, my motherboard is Asus N13219, can I use DDR400 RAM on it? (The old one is DDR333) PS Happy new year! Steven
cdhardy
  • 111 Answers
SOURCE: asus a7n8x MB and ram
i just checked & yes you can from what i was reading
Posted on Mar 30, 2008
  • 96 Answers
SOURCE: Plugged the wrong RAM and now the motherboard only lights up HDD LED
Try turning the computer completely off, pull the plug, then push down on the power button for 5 seconds, then connect the power plug again.
This would be a last attempt. It may restore your system to working order only if no permanent damage was done by having the wrong type of RAM in your machine.
Otherwise the motherboard may need to be replaced.
Posted on Jul 11, 2008
  • 987 Answers
SOURCE: In my Asus P5S800-VM motherboard, it won't accept 2 ports of RAM
Check the RAM in another machine if it worked then the RAM slot might have some problem....
Posted on Mar 30, 2009
  • 18 Answers
SOURCE: adding memory to Asus p5v800-mx motherboard
if they are compatible with your motherboard, different versions of RAM do not conflict
Posted on May 04, 2009
  • 141 Answers
SOURCE: ASUS P4S533-MX MOTHERBOARD FAILED TO RECOGNIZE DDR400/DDR333 RAM
Running two different speed memory sticks is a problem. All memory should be running at the same speed so take the DDR333 out and the beeping should stop. Alternatively take the DDR400 out and again the beeping should stop.
That's probably the shortest and easiest solve I've had for ages.
Happy computing
Posted on Apr 24, 2010
I need to upgrade my pc ram, pulled the ram and infineon is the manufacturer, they no longer make ram so how do I know what other ram I can put in my motherboard, got number from stickers on the...
Look for labels on the RAM: PC100 or PC133 or DDR266 or DDR333 or DDR400 or PC2100 or PC2700 or PC3200.
Since you cited 'DDR400', you need to purchase 'DDR400' RAM.
Any sales-person in any computer-store can sell you 'DDR400' RAM.
Feb 03, 2011 | Abit NF7-S (V2.0) 400MHz FSB nVidia...
I am using Intel D865GBF board having Dual Channel DDR400/333/255 SDRAM memory support. It is of 3GHZ, 256 MB RAM. The other day I bought 1GB RAM of Transcend and tried fitting the same. But the PC never...
Yes it can support 1GB ram. Max capacity up to 4GB of ram, meaning 1GB each on each slot. Make sure that the memory that you will be installing are either DDR400, DDR333 or DDR266. It could be the RAM is faulty if the one you bought is the DDR's that I mentioned
Oct 11, 2010 | Intel D865GBF Motherboard
I PLUG IN 2 NEW 512 MEM PCBS & WLL NOT BOOT. 1 BEEP FOLLOWED BY 3 BEEPS FOLLOWED BY 3 BEEPS FOLLOWED BY 1 BEEP. THEN NOTHING.
Remove the "new" RAM.
Look at the labels for PC2100 or PC2700 or PC3200,
or for DDR266 or DDR333 or DDR400.
Compare with the label on one of the "old" sticks of RAM.
Be sure that the labels on the "new" RAM are "equal" or "higher" than the labels on the "old" RAM.
For example, if the "old" RAM are DDR333, then you can use DDR400, but your computer will not accept DDR266.
Reinsert one of the sticks of the "old" RAM.
Does it still beep multiple times?
If not, then the new RAM is *NOT* compatible with your computer.
Jun 15, 2010 | E-Machines T1742 PC Desktop
Ram used for asus P5P800S
2 x 184-pin DIMM sockets support max. 2GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory.
Or if you prefer it a bit plainer a maximum of 2 x 1GB DDR400/DDR333/DDR266 SDRAM memory.
you will find the full specs as well as the drivers on the asus global website.
Mar 18, 2010 | ASUS P5P800S (90MBL0Q0G0UAYZ) Motherboard
In you case compatibility is your problem or your memory needs a clean up. First clean up the memory's pins. Use a pencil eraser. Then try only one by one so that you will know if there is a problem in each memory. Insert one of the memory then turn on your PC. If it boot up or it is okay try the other one. Then if it is also okay, try both of it inserted and turn on your PC. If it not okay there is a compatibility problem. Make sure the brands are the same so the compatibility are never be a problem.
Mar 10, 2010 | ASUS P4S533-MX Motherboard
Is their a special make of memory card, ie: ddr
According to: http://www.shopping.com/xPF-VIA-MB-FOXCONN-VIA-KM400A-400M01-G-6L-R
this motherboard has 2 slots for DDR (184pin) RAM,
and supports a maximum of 1GB of RAM per slot.
Note that DDR RAM comes in 3 speeds: DDR266 (slowest), DDR333, and DDR400 (fastest).
Buy the fastest RAM -- if the motherboard cannot run the RAM at "full" speed, the RAM will automatically slow itself down to a speed that the motherboard will support.
Sep 15, 2009 | Foxconn 400M01-G-6L Motherboard
Adding memory to Asus p5v800-mx motherboard
May 04, 2009 | ASUS P5V800-MX Motherboard
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
Recommended memory for p4i45gv R5.0
IF UR RAM IS SDRAM THEN U CANT UPGRADE TO DDR BUT IF ITS ON DDR RAM THE U SHOULD B ABLE 2 UP GRADE 2 1GIG OV DDR RAM RUNING AT 400MHZ
Dec 25, 2007 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
621 people viewed this question
David Payne
David Payne
