Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My washer is leaking water from the bottom for last 3 loads. What is the problem and can I fix it?
  • 132 Answers
You could turn on side on something soft and check pipes are attached or damaged
Posted on Jan 01, 2011
I have a Kenmore 80 series about 4 years old and it is leaking. Had a repair man over 3 months ago and it did not leak. However, I see my baseboard behind the washer pulling away and ran a small load...
check to make sure the drain hose is all the way in the drain pipe in your wall. there should be a strap, or tie wrap holding it in place to keep the water pressure from pushing the pipe out of the drain during the drain cycle. if not, the water pressure will cause the drain hose to rise up and allow water to leak down the wall. use a flashlight. you should be able to see a trail of water residue leaking down the wall. slide the washer out a bit and run it. see if the water is coming from the wall, or leaking out of the washer itself. let me know and we can go from there.
Nov 20, 2010 | Kenmore 24902 Top Load Washer
I have a Frigidaire Gallaxy Series top loading washing machine, 4 years old that seems to be leaking from the bottom. Is this something I can fix myself? THANK YOU.
Before you buy a new $100 door gasket, pull out the soap dispenser tray and look inside the washer where it normally sits. If there is significant soap accumulation (even 3/8 inch), the water can become backed up and trickle down the washer front to the door bottom, making it look like a door leak. Fixed mine this way.
Jul 30, 2010 | Washing Machines
Water leaking from the bottom of washer
I had this problem the other week we turned the machine around and took off the water hose got to the water pump and found 5cents, hair pins, badges ect in there once cleaned out and put back together worked great again and no more leaks!
Apr 26, 2010 | KitchenAid KAWS850L Top Load Washer
Leak underneith washing machine
Tip washer to inspect belts & hoses on bottom. Check hose connections & plastic pump housing for crack.
Nov 04, 2009 | Westinghouse WWS833ES Super Capacity Top...
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water on my floor
Is it the bottom or coming out the door at the bottom? When your seal is bad it will leak, mine leaks only on handwashables and delicates. I have had to have my seal replaced twice in the three years i have had one, and the last seal was not put on right and leaks.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking in on the left side of the washer on bottom
you can remve the lower acess panel (3 screws along teh bottome front panel) too look to see where it coming from. the top also removes with 3 screws along the top of back panel
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
GE Front Load Washer
Removing the lower front panel (3 screws nearest floor), and opening the round, white water pump filter cap (be ready to catch about 2 gallons of water!) is the best place to start. All you need is a Phillips head screwdriver and a large, flat pan (deep turkey tray works well)!
YOU WILL NOT BELIEVE what I found in my filter housing this morning (see photo below)!
The washer is working fine now, although I may go back and remove the entire water pump so it can be dismantled, thoroughly cleaned, and reinstalled.
Mar 16, 2008 | GE WSXH208A Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
156 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
