Cmos checksum error-defaults loaded..........how do i fix this ????
    President:
  • 1,314 Answers
This is likely because the CMOS battery on your motherboard has gone bad. It needs to be replaced. Usually it is a CR2032, available most anywhere. After installed, you'll get the message again, just go into BIOS and set your date and time and then you won't see it anymore.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 09, 2008
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
Cmos checksum error & keyboard not function
CMOS checksum errors
Explanation: A checksum is computed as an error-detecting code, to protect the BIOS settings stored in the CMOS memory. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, an error message is generated to tell you that the CMOS memory contents may have been corrupted and therefore some settings may be wrong. BIOSes react in different ways to encountering this sort of error. Some will warn the user and then continue on with whatever settings were in the CMOS. Others will assume that the settings that were in the CMOS were corrupted and will load default values stored in the BIOS chip "for safety reasons". The error message will indicate which your system is doing.
Diagnosis: The most common cause of checksum errors in CMOS is a battery that is losing power. Viruses can also affect CMOS settings, and motherboard problems can also affect the stored values.
Recommendation: Follow the instructions in this section to address the CMOS corruption. You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent BIOS settings backup).
Sep 24, 2010 | Computers & Internet
WHILE BOOTING MY PC I GET A PROBLEM OR ERROR NAMED AS CMOS CHECKSUM ERROR DEFAULTS LOADED
Usually when I see this problem it is because the cmos battery is bad. Replace the cmos battery and see if that fixes the problem. If it doesn't, then you really do have a problem. :)
Mar 10, 2010 | AMD Sempron 2800, 2.0 GHz 2800+...
Cmos checksum default loaded.tell me how to fix the cmos setting.
cmoschecksum default loaded. tell me how to fix the cmos setting
Dec 27, 2009 | Shuttle AB52 Motherboard
Ref GA-81PE1000L Error message on boot up
all the computer bios settings are stored even when the computer is off (like time and fsb)
these are stored due to the help of a cmos battery
when this battery finishes it gives the CMOS Checksum error Default loaded error
all you need to do is replace the cmos cell
it is a mercury cell (looks like a silver coin) and will be placed on your motherboard
it is very very cheap so go buy one and replace it and be happy
Sep 30, 2009 | Intel Motherboard
CMOS Error
Are the CMOS batteries good?
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
CMOS checksum error
rahul23petit
"CMOS" checksum error default loaded" means ur mother board cmos battery fail (which is locate at mother board), to solve this problem replace it by new one (u can buy it form any computer accessories shop). all oher problem happen for it.
Jul 06, 2008 | EliteGroup BKi810 Motherboard
Cmos error
ok, a checksum error can refer to a flat cr2032 cmos battery, especially if the time is wrong at every boot.
May 26, 2007 | Intel SuperMicro SUPER Motherboard - 810...
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
