I have a samsung 65"
  • 10 more comments
  • Chris Galassi Jan 02, 2011
    HI, sorry I meant to put 56". Well as far as I know it is the original lamp. I just finished cleaning out the back ... fans, boards, etc. The lamp you are talking about is on the bottom all the way to the right in a pull out frame? The model # HL56A65OC1FX7A. All the fans are working properly. Let me know asap... Thanks Chris
    So even though it gets very bright and then turns off , I need a new one . What causes it to turn off ... Is there a limit or a sensor that knows it is worn out?
    Or is it pulling to much resistance on is too hot?
    Thanks, I just ordered the lamp last night. I printed out the user manual and it also said when the green lamp light and the red temp/standbye light are blinking and after 20 min of trying all three lights stay on the lamp needs changing . I will let you know how it goes after I install the new lamp. Thanks again for all your help...Chris
  • Chris Galassi Jan 04, 2011
    I printed out the owners manual and it told me what the problem was, that the lamp is going bad and needs to be changed... Thanks
  • Chris Galassi Jan 08, 2011
    Ok, replaced lamp... same issue??? The model number is HL56A650C1FX7A , the light which are blinking are the ... standbye/temp and lamp light . It keeps trying to start and shuts off and after 20 min. of this then all three lights are on and not blinking, the third is the timer light. also inthe manual it says the two blinking lights are .. the lamp door is not closed correctly .. if I hold in the door switch it does the same.. wtf is wrong
    Ok got the lamp installed it, same thing is happening.. dont know what to do?
    OK got the lamp installed it , same thing is happening ... what can this be?????
    The fan does run when the lamp comes on , the only time the fan shuts off is when the tv resets and stars up again after trying to start. Maybe the fan is weak?
    what am I looking for ... if the board looks bad or any way to make sure if its bad or good?
    It is firmly in place ... now what?
    The connection is firmly in place... now what?
    Genius:
  • 1,126 Answers
The lamp needs change out. The lamps may look good , but what happens is they build up a internal resistance and they get to the point where the it takes a long time for the unit to come on, or it will shut down, and then get where it will not come on at all.
Posted on Jan 02, 2011
  • 4,889 Answers
Please tell me the exact model number of the tv so that I can tell you what the blinking lamp light means and how to fix it. I do not wish to provide generic advice.
Posted on Jan 03, 2011
  • 5 more comments
  • eagle338
    eagle338 Jan 04, 2011
    Ok. Glad to hear that you have figured it out. If you have any problems with replacing the lamp, then let me know.
  • eagle338
    eagle338 Jan 08, 2011
    When the two lights are blinking, does the fan behind the lamp run? The timer and lamp lights are blinking then you have an abnormal temperature issue, so we should start by checking if the fan is running when the two LEDs are blinking.
  • eagle338
    No the fan is ruled out. Its turning off only because the tv is resetting itself. The next thing to check would be the connector that goes from the cover detection switch(that clicks when the lamp door is closed) to the digital board is plugged in. IF it is then we will move on to the temp sensor.
  • eagle338
    Like I said, you are looking for a connector that goes from the door switch. Follow it and it will lead you to the digital board, which is the one near the analog board(which has all the inputs). Check to see if the connector is firmly in place and not loose.
  • eagle338
    Ok. Next thing to try would be to short the pins on the connector(marked as CN101 in the image). Short the red and yellow wires and see if the lamp comes on. If it does not, then it is either due to a faulty replacement(can happen if you have purchased the lamp from a third party source). Check the lamp filament for signs of damage or a sub-detect board fault. Check the filament status and short CN101 and update me.
  • eagle338
    Didn't you read my last comment? Click on the view more comments link at the bottom of the solution.
  • eagle338
  • 10,594 Answers
Let me know model number of this 65 inch Samsung tv.
Did you replaced lamp in tv or it is still running on old lamp?
Thanks.
Posted on Jan 01, 2011
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Jan 02, 2011
    It seems tv needs lamp replacement as existing lamp has been reached at end of its working hours life and causing problem, it is not dead or broken yet but can say got weak.
    Required lamp is available with Samsung Part Store for $140, click that link to view lamp image and price info.
    Please buy Samsung original lamp for good picture in tv. Lamp replacement procedure is easy and written in user manual.
    Thanks.
    Yes, thats corretc, it is lamp that is on the bottom all the way to the right in a pull out frame.
    When lamp start consuming more current than its rating due to its age, that activates protection circuit in tv.to avoid any damage of ballast supply and power supply. Over heating will kick temp sensor and you will see Temp led lit on tv front.
    No problem, you may accept solution to close question thread, thanks.
Samsung 60" DLP - 6
Hello.
It looks like you ignored lamp replacement in your TV. It have to be replaced every 2.5 years of average use. It's like oil change in a car. Regular scheduled service.
You can read info about lamp replacement in your TV owner's manual, buy lamp on-line and replace it by yourself to save some money.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
DLP TV lamp went out, new one doesn't work either,
Well you have a Samsung TV, in this case, it's most probable that you might have an issuw with your ballast. It might not have enough energu to keep up with your new lamp. You might ask yourself, How could this be if it worked with the old lamp? Well the old lamp didn't have all of it's gases, like it used, when you recently purchased the tv or lamp, and as time goes by, those gases tend to go out.
Aug 11, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
I have a 61" samsung dlp. It worked fine
Start with replacing the lamp. Then move on to the Ballast. Then the color wheel. Then the Power Supply. One of those parts should fix it. If not call back.
Jul 15, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Lamp light no pic
yes yes yes.the lamp needs replacement. you are very correct.that is the indication of lasmp replacement which your tv is signalling.replace it quickly.
howto replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
Mar 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Samsung DLP HL-S5086
Vertical problem and most likely a bad capacitor in the Vetical out circuit or IC.
Nov 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
