Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
The red light is blinking 10 times. Fault code says...unexpected gas flow present. Shut the gas off and still blinks 10 times.
  • 111 Answers
Turn power off to re set code.I'm not familar with that code.they are usuall 1 to 6 blinks.are you looking at the list on cover to get this?is this heat pump with propane back up?is there a flame sensor? Does flame come on and then go out?not at all?
Posted on Jan 01, 2011
SAMSUNG UA60H700 TV not powering up
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 14, 2016 | Televison & Video
Why my Sony Wega tv standby light blinks 10 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 23, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have Sony Bravia 46in model kdl-46w4150 it was working fine then just shut off and red standby light blinking 14 times. I've unplugged and tried to turn back on but still just goes to red standby light...
14 times blinks is a rare case to Sony Bravia sets. Just count it one more time.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Aug 06, 2014 | Televison & Video
I have Sony Bravia, m/n KDLHX800 and just shut off by itself. Blinks 7 red lights and never comes on. Unplugged from power strip and left for 1 hr, plugged back in and still just flashes 7 red lights
Jul 27, 2014 | Sony BRAVIA Televison & Video
WHEN PLUGGING TV IN, RED LIGHT BLINKS 10 TIMES BUT DOESNT COME ON
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 18, 2017 | Panasonic Viera TH-42PX80U Plasma TV
Amana Air Command 90 furnace LED light blinks 3 times pause 3 times
TRI-COLOR (DSI LED) DIAGNOSTIC TABLE
No. of Red BLINKS
1 Flame sensed when no flame should be present
Verify the gas valve is operating and shutting down properly. Flame in burner assemble should extinguish promptly at the end of the cycle. Check orifices and gas pressure.
2 BLINKS Pressure switch stuck closed/ inducer error
Pressure switch stuck closed. Check switch function, verify inducer is turning off.
3 BLINKS 1st-stage pressure switch stuck open/inducer error
Check pressure switch function and tubing. Verify inducer is turning on the pulling sufficient vacuum to engage switch.
4 BLINKS Open limit switch Verify continuity through rollout switch circuit.
5 BLINKS Open rollout/open fuse detect Verify continuity through rollout switch circuit, check fuse.
6 BLINKS 1st-stage pressure switch cycle lockout If the first stage pressure switch cycles 5 times (open, closed) during one call for heat from the thermostat the control will lockout.Check pressure switch for fluttering, inconsistent closure or poor vacuum pressure.
7 BLINKS External lockout (retries exceeded) Failure to sense flame is often caused by carbon deposits on the
flame sensor, a disconnected or shorted flame sensor lead or a
poorly grounded furnace. Carbon deposits can be cleaned with
emery cloth. Verify sensor is not contacting the burner and is locatedin a good position to sense flame. Check sensor lead for shortingand verify furnace is grounded properly.
8 BLINKS External lockout (ignition recycles
exceeded where flame is established and then lost)Check items for exceeded retries listed above and verify valve is not dropping out allowing flame to be established and then lost.
9 BLINKS Grounding or Reversed polarity Verify the control and furnace are properly grounded. Check and reverse polarity (primary) if incorrect.
10 BLINKS Module gas valve contacts energized
with no call for heat Verify valve is not receiving voltage from a short. If a valve wiring is correct and condition persists, replace module.
11 BLINKS Limit switch open - possible blower
failure overheating limit Possible blower failure, restricted air flow through appliance or duct work. Verify continuity through limit switch circuit and correct overheating cause.
12 BLINKS Module Ignitor contact failure Fault code indicates the module ignitor contacts are not functioning
properly. Replace module.Solid Module - internal fault condition Module contacts for gas valve not operating or processor fault.
Reset control. if condition persists replace module.
3 double 2nd-stage Pressure Switch Stuck Open/Inducer Error
Check pressure switch function and tubing. Verify inducer.
Nov 11, 2013 | Patton Electric Patton PUH680-U Electric...
Plasma tv th-42pd50u not come on and keep blinking red light two times and then stop again blinking red light two times and then stop not come on
The light blinking twice means there is a fault within the system and it is a code to tell Panasonic where roughly the fault lies.
Go to Panasonic's web site and look for your set then input the fault code and hopefully they will tell you where the fault lies.
Oct 16, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Me too
1.Not an expert with natural gas furnaces.
2.Statements below are from my own personal experience, and knowledge from.
The red blinking light you see is on a computer control board. The flashes of the red light represent a type of code. Think of it as a Morse Code, if you will.
For example: Red light blinks three times rapidly, pause, then blinks one more time. This code represents a particular fault. (Fault = Problem)
There is a sticker, with a chart of codes listed for this red light. It is usually placed very near the red light.
A gas furnace should be repaired by a competent HVAC technician. This is not a device that should be attended to, by those who are not trained.
An HVAC technician will know where to look, what parts are needed, and if the gas furnace is safe enough to put back on line. (Safe enough to use)
Sep 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Heating & Cooling Logo
300 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
