Question about Haier Heating & Cooling
My 1 year old Haier Room Air Conditioner HWR24VC5 will not cool. Everything runs; but when you select cool, the compressor doesn't kick in. Or let's say, the sound of the unit doesn't change like it used to. Also it looks like during a storm, the unit sucked in dirty water. Any suggestions?
  • 6,487 Answers
Try cleaning first your unit , because this problem can be cause of dirt inside it.
Hope that helps........
Posted on Jul 08, 2008
    Master:
  • 848 Answers
Your compressor might not get proper power supply that may be the reason for you ac not cooling
  • gopinath pasupathy Jul 08, 2008
    your temperature sensor is also not working properly
    Genius:
  • 1,142 Answers
Yes the thermostat needs a check
  • Haier Master
  • 19,396 Answers
It may be time to recharge the gas, contact a service in your area
  • Ginko
    Ginko Jul 08, 2008
    You get contact and instructions on how to get service in the last pages of the user manual, it can also be a fauty compressor. Check that you are using setting correctly before calling service.
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Kenmore 580.15151500 Compressor doesn't turn off
Most likely is a issue with the temperature sensor that when it reaches the level selected is not turning the compressor off.
Jun 15, 2012 | Kenmore Room Air Conditioner
Air conditioner not working
have you tried turning off and on power from the plug ?
Aug 17, 2009 | Haier HWR08XC7 Air Conditioner
Kenmore room air cond fan runs, no cool. checked
if the fan motor is on but the compressor is not : if the compressor has correct voltage up to the terminals and is not operating, the compressor is bad, if ther is not power to the terminals, the start components may be the culprit, if there is no power to the start componenets then the controller is the issue.
Jul 18, 2009 | Kenmore 75123 Wall/Window Air Conditioner
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
NO COLD AIR
If the fan and compressor are both running and no cold air then you’re low on refrigerant,
Thermostatic expansion valve closed or bad , dirty condenser or the valves are bad in the
compressor.
Apr 25, 2009 | Haier HWR10XC3 Air Conditioner
Haier air conditioner
On the Compressor? - Theres a run (R) that gets the red wire from the run capacitor or line side voltage, theres a start (S) that gets the yellow wire from start capacitor and theres a common (C) that gets the black wire which connects to neutral or common. If you ohm it out to identify the terminals the highest resistance is between (S) and (R) second is between (S) and (C) and least resistances is between (R) and (C). Hope this helped. GL!
Jun 14, 2008 | Haier Preference Plus HWR24VCA Air...
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
The reset on the plug
capacitor or compressor burnt
May 09, 2007 | Haier HWR24VC5 Air Conditioner
Heating & Cooling Logo
108 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Jamie Tai
Marat Brikov
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
