Question about Maytag Washing Machines
Spin cycle doesn't work, clothes stay soaked - Maytag Washing Machines
  • 95 Answers
Check the door switch for damage. If the switch is damaged, your clothes may wash, but will not spin out.
Posted on Jul 08, 2008
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
The washer will fill up and go through the cycles, it will drain properly, but then the spin doesn't work proprerly. It does not spin at quickly, only very slowly and a knocking sound will occur. When...
Since you didn't say what brand and model you have I can only give you generic advice. If its a GE washer, it has a belt and sounds like it may be very loose or/and worn out. Other brands have belts as well. if it doesn't have a belt then a knocking sound could mean the transmission is out.
May 15, 2011 | Washing Machines
MY MOFFAT WASHER SPIN SCYCLE WILL NOT WORK THE WASHER WIL NOT SPIN TO REMOVE THE WATER
moffat washing machine does not remove water after spin cycle
May 29, 2010 | Washing Machines
Even after doing the spin only cycle, my clothes
Is drum spinning on spin, check belt tension if not. if this is ok then it could be problem with motor brushes, or if it is induction motor it could be a capasitor
Feb 08, 2010 | Washing Machines
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Washer won't drain and clothes stay soaked
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
236 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
