Question about Kenmore 24 in. 17572 Built-in Dishwasher
I have a Kenmore Elite Ultra Wash dishwasher. Model #17572. All the lights on the control panel went out. Get no response at all. Circuit breaker is fine. Any reset tips? Or, do I need a new control panel?
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
SOURCE: Won't Power on!! Help its starting to smell bad
will not start
Posted on Aug 09, 2008
  • 13 Answers
SOURCE: Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
Posted on Aug 20, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
Why don't buttons on top panel work?
Do you mean that you have no response when the door is closed and you're trying to start the machine? My control panel becomes unresponsive when counter crumbs or dust gets into the tiny hole where the top of the door locks into the top of the dishwasher. Sometimes, it's as simple as just blowing into the opening, other times I need to use a tiny brush or q-tip to clean the contact in the top of the door where it locks into the control panel.
Nov 17, 2015 | Kenmore Dishwasher With Ultra Wash And...
Kenmore dishwasher water inlet valve replacement
Turn off power to dishwasher at the breaker or fuse panel.Turn off water supply usually found under sink. Remove the front kick panel and remove water supply line from the valve,remove clamp to hose on dishwasher and remove hose. Remove electrical connectors from the inlet valve and remove screws holding valve to cabinet . Reverse steps to install. Slowly turn on water and listen and look for leaks if all is well turn on the power and start washing.
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore ultra wash model 665 has lock on light. Does not respond to no heat dry four seconds.
Press and hold the heated dry button for 5 seconds and see if that will unlock the control panel. If not then try to flip the circuit breaker off for a minute and see if it resets. If nothing resets, then you just need to replace the control board because it's shorted.
Good luck.
Draven at www.ApplianceRepairLesson.com
Mar 04, 2011 | Kenmore Dishwashers
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
Kenmore 24 in. 17572 Built-in Dishwasher Logo
47 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
