Question about Fisher and Paykel Washing Machines
Washer skips first 2 wash cycles. goes in rinse cycle but does not spin out the water.
  • rowejukebox4 Jan 01, 2011
    you didn't explain why the first 2 wash cycles are skipped.
  • rowejukebox4 Jan 02, 2011
    you still haven't answered my question about why the washer skips the first 2 wash cycles. goes into rinse but does not spin out.
  • 2,382 Answers
Hi, if the washer doesn't pump or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Jan 01, 2011
  • Tunde Autos
    Tunde Autos Jan 01, 2011
    Hi, sorry about that. that should be a lid switch problem..
  • Tunde Autos
    Tunde Autos Jan 02, 2011
    It skips the first 2 wash because you have a lid switch problem, and it doesn't spin out because you either have a frozen puller or a broken pump belt if the motor is running and if the motor is not running, the lid switch is defective,
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
This is for a Whirlpool washer and dryer thin stack. All four of the wash cycles work AND all four of the spin cycles work, but the rinse cycles do not work. I have to manually skip it forward past the...
I would suspect the water inlet valve as being the problem,if it drains the water and spins the lid switch is going to be good.The thing exclusive to rinse cycles is that they only fill with cold water,and that is what i suspect the problem being is that it's not filling with cold water on the rinse cycle because of a bad water inlet valve.
GENE
Sep 12, 2011 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Jan 19, 2010 | Kenmore Washing Machines
Maytag washing machine skips rinse cycle
I found this problem with mine intermittently and it was because i had filled the machine too full that it was too heavy to initiate the spin. maybe try a lighter wash?
Jul 03, 2009 | Maytag Washing Machines
Machine stops and goes to end half way through a cycle
Check the filter is not blocked it sounds as if it cannot drain in the time allowd at end of wash cycle. Regards Advisor
Jan 17, 2007 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
