Question about Refrigerators
My Jennair refrigerator (Model #JCD2389DES) does not stay cold. The freezer is cold but the fridge is room temp. There was a bit of frost inside the freezer. Looked up some advice and was informed that cleaning the coils could help, but not sure how to access. How can I fix this?
    President:
  • 1,891 Answers
Clean the coils under the ref will help it to run less and cool better . and make sure the fan under there is going also . but the ice or frost that you found in the freezer is the problem . it has block the air flow that cools the fresh food side . this is caused by 1 ot three things . i would replace the defrost terminator on the top of the cold coil first and if this does not correct problem replace the defrost control ( timer or some times called the A D C . ) part # 6100 5988 ) the heater is pr # 61006199 and comes with the terminator . hopt this helps mm feed pack please ..
Posted on Jan 01, 2011
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
I have a Kenmore bottom fridge model #596.69274991. Although things are cold and frozen, the room temp is only 70 degree but it seem to run for well over an hour although there has not been much opening...
Tom, you pretty much have it all covered. Make sure both the freezer fan and the fan under the fridge are both running and keep your eye on the inside back wall of the freezer compartment fro any signs of frost build up (possible defrost problem).
Jun 12, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Model #GD5RHAXNB0 and the compressor keeps cycling. It is not cooling.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Aug 22, 2009 | Refrigerators
Freezer is cold but fridge is warm
check door seals for freezer and fridge. If ok, check frost level in the freezer. Ice present on the back of the freezer panel (evap cover) remove evap cover and check for defrost problem by ohming out heater and defrost thermostat. If both check ok, then test the defrost timer. If this unit new and covered under wty, call a&e factory svc at 1-800-905-9505 for a free repair. consult your owners manual for wty details.
Jun 25, 2009 | Sanyo SR-1030W Top Freezer Refrigerator
Fridge not staying cold
Inside the fresh food compartment there is a defrost timer hidden behind the temp control panel. Sometimes there is a plastic plug over the hole that you need to put a flathead screwdriver in and slowly turn it clockwise. When compressor stops I want you to wait about 25 minutes to see if the refrigerator comes back on by itself without help. If it does I need you to listen inside the freezer compartment for sa sound of crackling or sizzling noise indicating defrost is taking place. Let me know, Sea Breeze
May 19, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Black Maytag Side by Side MSD2756AEB 7+ yrs old? Won't stay cold...
Your condenser where the heat is removed from the refrigeration system may be plugged with dust. The condenser is more than likely located in back of the refrigerator behind a removable panel. Remove the panel and clean it out. Reinstall the panel after you have cleaned the condenser.
Check the back wall of the freezer for frost buildup. If there is frost buildup on the back wall it indicates that there is a problem in the defrost circuit.
Note: The proper term is "More mature individual" , not old.
May 31, 2008 | Maytag MSD2756GES Side by Side...
Fridge running but not staying cold
you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
Jan 05, 2008 | Refrigerators
Jennair JCD2389G side by side
Can you tell where in the unit the buzzing is coming from (top bottom inside outside, etc)? Need a little more information to help.
Dec 04, 2006 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
211 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
