Question about Toshiba HDDR320E04XW 320 GB USB Hard Drive
I want to erase everything on my external hard drive. How do I do this?
  • 492 Answers
If you aren't sure what you're doing, bring it to a service tech or you may render that external hard drive completely useless:
Before you start cleaning make sure you back everything up onto another disk. If you are giving your computer away check with the person or organization to see if they plan on cleaning your hard drive for you. However, the best thing to do is to clean it yourself.
Download a hard drive cleaning program or go to a computer store that sells computer software and buy the program. This is the safest way to make sure the hard drive is all wiped clean. Running the software program over writes all the data on your drive, making the hard drive impossible for anyone to read. The software works by over writing the drive many times.
Make sure you give yourself plenty of time in wiping your hard drive clean because if you have a lot of stuff it will take longer to clean.
Once your running your program and the box comes up to erase your hard drive don't forget that this process is irreversible. You will now type in the word format drive letter and hit confirm that you want to erase everything on your computer.
Installing a new external hard drive if you are not getting rid of your computer, is another option you have. You still go about erasing the old drive because you're getting rid of your hard drive. Install the new one.
Posted on Jan 01, 2011
My external hard drive os gives a clicking sound
Improve the FixYa experience for everyone by voting.
It sounds as though you have software incompatibility problem. With a bit of good fortune, Microsoft can diagnose the problem( s) and fix it in three easy clicks and it's free. CLICK HERE
If that doesn't do the job, you'll have to format the hard drive. Hopefully, you've been backing up everything on the external drive because the formatting process erases everything.
May 21, 2012 | StarTech.com InfoSafe Mobile 2.5" USB 2.0...
Hi i have a smartdisk crossfire external harddrive which I have used to save my photos from a windows based pc. However I have now purchased a IMac and wish to be able to load my photos on to this. When I...
congratulations on switching to mac!plug the external hard drive back into the PC, and copy the photo's to the PC, now plug it into your mac and go to applications-utilities-disc utility, the external drive should be listed on the left,click on the erase tab, at the volume format select "ms-dos file system", then click the erase button, this will erase everything on the drive and set it up so your mac can use it (but its ok because you moved all your pictures to the PC) now you can go back to the PC and copy the pictures on the external drive and it will work with your mac.
Jul 04, 2010 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Reformatted the external hard drive and lost files
Unfortunately, there's no way to retrieve any PC files. Once you reformat your external HD, everything would be erased.
Thank you!
Jan 04, 2010 | Computers & Internet
External hard drive isn't recognized!
try pluging it into a different usb port try a different cable if they all do not work then the partision table has been damaged and the drive will have to be reformatted
Dec 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
How do I install my seagate freeagent external harddrive into my macbook? my computer keeps asking whether I want to erase everything on the hard drive first. I'm afraid it will erase any software that...
the soft ware that comes with it will also be erased, as it is a windows based identification,seagate free agent has mac utilities on its site, try to find out on www.seagate.com. you will find one for mac format and mac installation .
Dec 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Help!
You have not yet formatted the drive to work with you MAC. You will need to use your MAC's Disk Utility to format the drive in order to write to the drive, but be aware that formatting will erase everything already on the external drive, so back up anything on the drive you want to keep first.
May 29, 2008 | Seagate 400GB 7200rpm External HDD Retail...
Erase and reformat to be compatible with new mac
Think I might have solved it myself. Here's how:
Open Disk Utilities and select the external hard drive. Select the "Erase" tab. Hit "Erase" at the bottom right.
That's all. Just dragged a folder onto it and it worked.
May 08, 2008 | Maxtor OneTouch II external hard drive...
40 GIG EXTERNAL
Are you familiar with hidden files and/or using the Terminal application? Hidden files could be the cause of your disk usage and you could use Terminal to verify and remove the files. The easiest way to erase the drive and restore the space, though, is to use Disk Utility and erase the partition. Open Disk Utility Select the Volume name Click the Erase tab Click the Erase button BE SURE YOU HAVE NOTHING ON THE DRIVE THAT YOU WANT! Please let me know if this helps or if you have more questions.
Aug 22, 2007 | FireLite (USBFLB80) Hard Drive
Toshiba HDDR320E04XW 320 GB USB Hard Drive Logo
212 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
