Question about Thermador SC302T Electric Double Oven
Display is very dim and can hardly be seen in daylight
  • Thermador Master
  • 2,605 Answers
Welcome to FixYa.
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available.
You can find these "display kits" at "repairclinic.com" for around $275USD and includes what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Posted on Jan 01, 2011
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Mar 19, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
Have a Jenn_Air WW30430 - display is barely visable. Can you tell me if changing the capacitor will work?
HI,
You have an LED display, changing anything other than the clock would not fix your problem. I am assuming you oven get daylight directly on the screen as well. Direct daylight can speed up the process of a fading display also...
Hope this hopes
Jul 28, 2011 | Jenn-Air 27 in. Electric Single Wall Oven...
Display for double oven is dim and hard to read
You need a new touch pad display for this unit. Call us with your brand and model number and we'll get the right part out to you asap! We look forward to working with you!
Oct 17, 2009 | Ovens
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
The light and temperature display are very dim and hard to see.
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 23, 2008 | Jenn-Air JJW8230D Electric Double Oven
Kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Oct 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Unfortunately this is a bad display, and the kit to fix it (comes with new display board and power/relay board) is about $270 for the parts, and if you cant put it in yourself expect to pay an additional $120-$220 depending on rates in your area. Wish I had better news, but I see these (and Dacors) do this frequently. Hope this helps.
Nov 10, 2006 | Thermador SC272T Electric Double Oven
Clock display too dim
You are going to need a display kit to fix this. It comes with a new display and relay board. The kit is about $200 and is somewhat difficult to install. This repair altogether usually runs about $400 to fix if you dont have someone handy that can do it for you. It involves removing and replacing at least 20 wires from the relay boards, as well as either pulling the oven from the wall or working in a tight space to change the board. You may be able to find just the display board somewhere, and that is very easy to install, but I've only ever gotten the part as a kit. Hate to be the bearer of bad news. Good Luck!
Aug 16, 2006 | Thermador C301U Electric Single Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
90 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
