Question about Directed OHD1021 Car Video Player
No power at the unit all of a sudden - Directed OHD1021 Car Video Player
    Sergeant:
  • 436 Answers
The fuses for the roof monitors are normally in the wiring behind the monitor although if you have had it a long time and use it regularly the ribbon may have broken in the hinge.
Posted on Jan 01, 2011
Testimonial: "Do you mean I need to drop the head unit to see these fuses or is it behind the display flap itself? Also where do you get a replacement ribbon? "
Kenwood VR 605 power light flashes
CHECK FOR CLEARED COOLING VENTS & FOR PROPERLY WORKING COOLING FANS. THIS WILL CAUSE SHUTDOWN OF THE UNIT. IF ITS ALL CLEAR, YOU PROBABLY HAVE A POWER SUPPLY ISSUE.
Dec 10, 2013 | Kenwood VR-605 Receiver
Sudden power loss
have the fault codes read and replace faulty units
Apr 03, 2013 | 2004 Honda CR-V
Hello i hava aq-see qt426 surveillance system and after a power outage it won't boot, keeps rebooting and freezes on 'system initializing" screen. do i have to format the HD or it could be...
you need to format the HD. The sudden power outage is the reason the unit is freezing. As a matter of fact, the HD is the cause of the freeze. The HD has not been able to recover from the sudden power outage.
Format the HD and hopefully the unit should be back to normal.
But if unit is not in order after formatting the HD, please let me know for further direction.
Good luck.
Jun 23, 2011 | QPS Q see QT426 Video Surveillance System
The light went off on my house and when the electricity got back my lcd viewsonic 32" N3252 doesn't turn on also the Red light is off any ideas
When power suddenly goes off from the main source, it tends to damage a component or the other inside a unit, because it was sudden and the unit did not go through a proper shut down process.
If your unit does not come on, and there is no sign that power is coming in, then it means there is a power problem, because there is no power supplied to the unit.
First try to plug the television to another another power outlet to see if it works, then try using another power cord, after doing that, also try to plug the cord to you HDMI port, if it does not come on still, then it means the power panel is faulty and needs to be replaced.
Take care and good luck.
Oct 28, 2010 | ViewSonic N3751W 37 in. LCD Television
Sudden Shutdown of the unit, I Cannot use my FP72E BenQ LCD monitor Properly because at the middle of using it, it suddenly shutdown, open, shutdown again, open again. is this unit is capable for long...
For the monitor that is more than 2 years old, first place to look will be the power supply, look for bad caps with bulging top first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Feb 16, 2010 | BenQ FP72E 17" LCD Monitor
Just quit suddenly. Power at oulet, nothing lit
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms (dead).
Nov 27, 2009 | Panasonic NN-T964SF Microwave Oven
Our unit turned off suddenly one day, and now you
If it trips almost instantly then you have a serious power supply rail problem rather than just a channel down. You need a Yamaha specialist to look at it, there aren't any fuses for that.
Oct 24, 2009 | Yamaha RX-V595 Receiver
Directed OHD1021 Car Video Player Logo
170 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
