Question about Back to Basics Disney Popper PD5 Popcorn Maker
Popper won't heat up
My Disney popcorn popper has stopped working. It won't heat up. However, the stirrer still spins. Any ideas?
    Master:
  • 505 Answers
Sounds like the heating is broken or faulty
Posted on Jul 18, 2008
    Sergeant:
    Champion:
  • 417 Answers
Heat mechanism is broken
Posted on Jul 17, 2008
Popcorn popper isn't popping popcorn
If it heats up, your popcorn may be old and dried out. If it doesn't heat up and the stirring rod does not turn, check your power cord for defects. Procedure: plug in the popper (check both ends of the cord!), turn it on, and gently wiggle the cord right at the plug or where it goes into the popper, and watch the stirring rod to see if it moves. If it starts and stops as you wiggle the cord, you've found the break in the cord. Repair it or replace it (West Bend lists it online for $5) and be more careful with the cord in the future (never unplug by yanking on the wire, always pull on the plug itself).
If the stirring rod turns and there is no heat, the thermostat or thermal fuse is probably open. This can happen in some poppers if the air vents are blocked on the bottom. Remove the obstruction from the vents, let everything cool off, and try again. If it does not heat up from a cold start, there may be a blown thermal fuse inside. If you decide to replace the thermal fuse or thermostat, it MUST have the same temperature and current rating as the original.
Jun 17, 2016 | West Bend Westbend Popcorn Popper Stir...
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Jan 09, 2014 | Nostalgia Electrics KPM-508 Popcorn Maker
Popper does not work when plugged in
the heat coil shorted the fuse blew; throw it away
Dec 03, 2013 | Kitchen Appliances - Others
Paragon Popcorn Popper Thrifty Pop 4 OZ Parts
I run a part-time hot dog stand in Nashville, TN. I've bought parts from Fine Entertaining . I'm better sure they sell popcorn popper. Paragon Popcorn Popper Thrifty Pop - the manual is under the resource section.
May 25, 2012 | Paragon Theater Pop 4 Popcorn Maker
I've lost the instructions, how do i use it
this video should help http://www.expotv.com/Back-to-Basics-Disney-Popcorn-Popper/2f-fPq
Oct 31, 2010 | Back to Basics Disney Popper PD5 Popcorn...
Use
Is the heater heating? Please check it ... Plug it into the outlet ... and put your hand GENTLY on the burner to see if it heats up. Of course, if it gets hot ... remove your hand.
I suspect the heater is not functioning 'pop'erly ...
Thanks for your interest in FixYa.com
Jul 15, 2010 | Back to Basics Disney Popper PD5 Popcorn...
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
My popcorn machine wont heat up
First, if you have another cord like this one (for example, a coffee pot cord) plug it into the popper and see if it works.
If it's not the cord, it's probably a blown thermal fuse inside the unit. Could be a heating element broken as well. If you don't have appliance repair experience, I would take it to a repair shop.
May 03, 2009 | Cretors Goldrush Popcorn Maker
Rod will not turn when popper is plugged in
I once tried to get parts for a West Bend popper with no luck. I just kept using it without the stirrer.
I would say from a pure economic standpoint, you're better off getting a new one. I don't know that one brand is any better than another -- it's just potluck from my experience.
Apr 17, 2009 | West Bend 82306 Stir Crazy® Popcorn...
Replacment parts
Did you find the piece to your popper? I just dropped mine on the floor and broke it, so if you still need that little piece, I have it.
May 21, 2008 | Back to Basics Disney Popper PD5 Popcorn...
Back to Basics Disney Popper PD5 Popcorn Maker Logo
443 people viewed this question
Top Back to Basics Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Pierre Legault
Are you a Back to Basics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
