Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Our DLP tv after a while of being on begins to run diagonal lines that slowly gets bigger and then turns greenish and pink on either side of the lines. We have already replaced the bulb but it only stopped for a few minutes and then went back to same problem. Could it be the ballast? Is it easily replaced? How much is it?
charcois
  • 763 Answers
SOURCE: scrolling diagonal lines
try to see the input connection of it. it must have a loosen the connection everytime you put it. see also the settings or the menu it must have been out of tuned.
did you try to watch any dvd or vcd using your tv. see if still persist the problem.
cheers
CHARCOIS
Posted on Sep 01, 2008
Slinteriors
  • 8617 Answers
SOURCE: New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Posted on Apr 30, 2009
Slinteriors
  • 8617 Answers
SOURCE: green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Posted on Jul 22, 2009
  • 125 Answers
SOURCE: I have replaced the bulb in 73
replace the Lamp its going Bad 1-800-628-1118
Posted on Mar 25, 2010
  • 46 Answers
SOURCE: Screen turns off after few seconds.
http://www.discount-merchant.com/
Posted on Mar 27, 2010
Testimonial: "The response was very quick, and the place I was referred to is one of the best. However, it turns out that they don't carry the part I need."
Static lines on screen
Just adjust your cable while looking at the screen, the diagonal lines will slowly disappear
May 29, 2017 | Samsung DLP HL-P5663W 56" TV
Thin diagonal lines on screen. How to adjust whit balance ,screen end focus?
Is that diagonal thin line about 10 to 20 degree slant? And then you have a very bright raster?
Then you set the flyback(for tube tv), I think its "screen" voltage is set too high adjust it slowly to lessen the brightness. It is commonly a small pot on the side of the flyback together with the focus pot.
If you have raster turn the tv on, use insulated screw diver, then slowly turn the knob to the direction(CC or CCW) where your raster go dim.
Be careful your dealing with live and high voltage. If your not inclined on electronics better not to.
Oh BTW, set your settings to normal.
Sep 30, 2009 | Televison & Video
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
I also have diagonal lines running through picture. However, when
HI, the PIP runs through a separate stream and, is separate from the main. these lines are being produced by a failing DMD or, Light engine. You will need to replace this failing board soon. it is failing slowly.
Jun 25, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV bad picture
Some Samsungs have a problem if the set is turned on bfore the input put device due to a firmware issue. Try turning on the device (game, DVD, etc) BEFORE turning on the TV.
Let me know if this helped.
visit my site:
www.mcveyelctronics.com
May 02, 2009 | Samsung HCM5525W 55" Rear Projection...
Pink and greenish lines creating a double picture
with your remote go to your menu and find convergence. Follow the instructions to auto set convergence. if that don't fix it the problem convergence panel if bad.
Mar 15, 2009 | Philips 55PW9363 55" Rear Projection...
Diagonal lines through the picture.
I've found the lines caused by the digital board before. Unfortunately it is expensive. I'd recommend running it on HD and it will bypass the faulty circuit. The lamp light flashes telling you the lamp is firing up. As the lamp ages, it will take longer and longer until it fails.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Video channel has diagonal lines
check the connections from your video to your tv, sounds like you have a loose wire,
If not re-tune your tv , it might have lost the tuning a bit , but its probably a loose connection
Feb 28, 2008 | Televison & Video
Monitor Fading
get a new one of hp no luck thear just by a bigger beter one thean kick the old one
Feb 02, 2008 | HP mx705 17" CRT Monitor
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
168 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
