I need a code for tv remote supportplus sp-urc-81-l
free2rhyme
SOURCE: need code for remote control
To program a TV you can use the code search option. You do this by making sure the TV is turned on then point the remote at the TV then press the TV button once, then press and hold down the set button until you see the RED l.e.d light blink twice, then enter the code 991. Next press the power button then the TV button continue doing that until the TV turn off, when it does press the set button. Press the power button and the TV should turn on again.
Posted on Mar 25, 2009
pabloloco
  • 2335 Answers
SOURCE: I.Needs the codes for remote control one for all
I can help you to program your One for All Big Easy URC-3220 Universal Remote for your Sanyo Plasma TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Posted on Apr 11, 2010
BElectric
  • 1140 Answers
SOURCE: i have a currys essentia
I'd like to be able to give a more positive answer but I don't think this combination of remote and TV will work together. One-for-All do not list codes for Curry's brand devices. These are simply 'badged' TVs from an often unknown manufacturer.
As there are no codes listed for your brand, identifying a code which will work is limited to trying to identify the original manufacturer of the TV and hoping that your TV shares common components with a TV that your remote does have codes for. There are too many codes in the remote to try to guess a code or to try them all using the manual code entry method.
Your best option is to try the Code Search:
1. Switch the TV on.
2. Press the "DVD" button on your One-for-All remote
3. Press and hold the "MAGIC" button on the remote until the red LED under the POWER key flashes once, then twice.
4. Enter 9 9 1 using the number keys on the One-for-All remote
The LED will blink twice again, indicating that the code search is active.
5. Press the "POWER" button on the One-for-All remote
6. Point the remote at your TV and press the "CH+" button slowly and repeatedly until your TV switches off.
7. As soon as (or if) your TV switches off, press the "MAGIC" button again to store the code.
8. Test the remote with the TV for the common functions, i.e. POWER, VOLUME and CHANNELS.
9. If the TV does not respond (or does not respond as you would expect), go back to step 1 and continue the code search . This does not restart the code search from the beginning, it simply picks up from the code that is currently set and continues through the code list.
Please note: There are hundreds of codes stored in the remote so it can sometimes take half an hour or more to search through them all.
Your TV is a DVD combi so this means the correct code should be stored in the code list for DVD players. However, as it is impossible to discover the true identity of your TV, it is also possible that there may be a code that will work with your TV in either the TV or VCR code list. You can try repeating the code search as above, but in step 2, press either the "TV" or "VCR" button instead to run through the codes for these device types.
It is also possible to control some TV/DVD combis by using two codes. Run through the code search in "TV" mode first. If you can find one that will operate the TV functions, store it, then run the code search again in "DVD" mode. You may then find a second code that will operate the common DVD functions, e.g. PLAY, STOP, PAUSE, etc. If this method works, you simply need to remember to press the "TV" or "DVD" button on the remote first - depending on which function you are trying to control.
There is a "pot-luck" element to getting any universal remote to work with any device. There are hundreds (maybe even thousands) of universal remotes and thousands of brand/model combinations of TV. This means there is an almost incalculable number of combinations of TV and universal remote and expecting there to be a code for every device is unrealistic. Unfortunately, this element of luck also increases for devices from a lesser known brand and even more so when the TV is newer than the remote.
Please try the code searches as detailed above. This can require a lot of patience. If you still can't get any response from the TV, then it's unlikely that your particular combination is one of those that will work. You would also be taking the same chance with any other universal remote, even if you bought a new one.
If you can't get any results from the code search, please post back for further assistance.
Regards,
BElectric
Posted on Dec 30, 2010
NJFIRESTORM
  • 84 Answers
0054, 0030, 0171 are the only codes available for sylvania tvs with your remote
Posted on Sep 17, 2008
joeymille916
  • 143 Answers
SOURCE: i need the code my
http://www.oneforall.com/uploads/support/e04d2cffae9469f511770f5e563d5330.pdf Here is the manual for the remote... the codes for Quasar TV are... 0250, 0051, 0055, 0165
Posted on Oct 10, 2010
Need code for shrp tv
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Sharp TV's 0093.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
Find instructions here for the One For All URC-3021 Code Search.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
Jun 02, 2010 | One For All URC-3021 Remote Control
URC-3021 Remote Control: I need the codes for tv's....
Without knowing what brand of TV you would like to control, may I recommend using the URC-3021 One For All URC-3021 Code Search, or refer you to the One For All URC-3021 Code List?
I hope that helps.
One For All URC-3021 Manual
One For All URC-3021 Reassign Key
May 17, 2010 | One For All URC-3021 Remote Control
URC-3021 Remote Control: i need code for apex tv...
The codes for Apex TV's are: 0748, 0765, & 0767.
I hope that helps.
May 15, 2010 | One For All URC-3021 Remote Control
I need the codes for an RCA and Emerson TV
The codes for RCA TV's are: 0047, 1047, 1147, 1247, 1347, 1447, & 1547.
The codes for Emerson TV's are: 0154, 0236, 0463, 0180, 0178, 0171, & 0623.
I hope that helps.
Apr 19, 2010 | One For All URC-3021 Remote Control
Remote code for rca tv
The code for RCA TV's are: 0047, 1047, 1147, 1247, 1347, 1447, & 1547.
For complete instructions on entering the URC-3021 remote code, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
Apr 15, 2010 | One For All URC-3021 Remote Control
I have a supportPlus 8 in 1 remote and no codes for it i require the set up codes for a htatchi tv please....
my supportplus remote will not turn on/off my NEI televisionset how do i programe it too work?
Dec 09, 2009 | Hitachi Televison & Video
I lose the remote control from my télévision daewoo....now I have universal remote control : SupportPlus- URC-L-1870....how to find the code for use this material ? Thanks Model Daewoo :DTE 28G7
Sometimes the manual that comes with the unit doesn't have the TV that you have listed; however, they will often give an alternative to cases like your, but if not, you might want to go to their website and go to customer support and e-mail them with your issue, and I am sure that they will be more than happy to assist.
Oct 19, 2009 | Televison & Video
How to tune sky remote without code
Hi There, I have a Hisense 81 cm Plasma PDP 3208 TPW 3208
I need code for my urc-7544 so I can use the remont on this TV
Thank you
Nelson
Cape Town
S A
Aug 16, 2009 | One For All URC 7740 Remote Control
I need the code for a celera tv
need codes for the URC-3220 remote control
Apr 21, 2008 | Quasar SP-3235 32" TV
Televison & Video Logo
1,091 people viewed this question
Top Televison & Video Experts
Electro Med Services...
