Question about Kurzweil SP4-7 76 Note Digital Stage Piano, Semi Weighted Keys, 128 Programs, 64 Split Polyphony, Split Layer, Setup Mode, 24 Bit DSP Technology, Black
I have a Kurzweil Mark-Pro TWOi. It takes several minutes to turn on, and keeps resetting and clicking while booting up. My guess is a bad capacitor somewhere. I looked at the power board, and it looks and tests out fine.
  • Kurzweil Master
  • 5,603 Answers
I don't know what you "tested" the power supply board with, but I would use an oscilloscope to look at the outputs to see if any of the regulators are drooping. Clicking is a broad term... if it is a relay, it PROBABLY is for speaker protection and senses balance of the power amps.
With a two minute delay, this is PROBABLY a thermal issue... Use freeze mist/circuit cooler to find suspicious parts.
Posted on Jan 02, 2011
  • Anonymous Jan 02, 2011
    I didn't post a very good description of the problem. The clicking sound is made out the speakers when the piano resets. It made the same sound when the piano turned on normally (but would only do it once instead of a dozen times). I'm fairly sure the problem is not related to the relay. There is a power amplifier on the amplifier circuit board that gets very hot while the piano is turning on, but after it is on and ready to go, cools down significantly.
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
Kurzweil M1 digital piano is resetting (shutting down and turning on) on its own in the middle of playing.
You're correct, that's a power supply problem, but it may also be the power supply connector on the keyboard. If you have access to a voltmeter, check the power supply first.
Apr 06, 2016 | Kurzweil Music
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page
Support Kurzweil
Feb 08, 2015 | Kurzweil SP3X 88-Key Stage Piano
Hello! I have the Kurzweil Mark Pro TWOi piano. Suddenly some keys make strange sounds through the speakers, like distrortion or noise. The speakers seem to be fine, because the demo songs play perfectly....
Try to re-initialize the unit(factory reset). If the keys are the problem then the rubber key contacts need to be cleaned or replaced. Contact a local service center for help.
Dec 09, 2014 | Music
Replacing battery in kurzweil mark 12
As per the manual it says it is located near the power switch. You will need(as per the manual instructions): a screwdriver(Phillips head), a knife, a pair of scissors, and a pair of front end wire cutters as, when shipped from the factory, the three AA batteries were taped or cable tied as a shipping precaution(to keep them from falling out). ***WARNING: MAKE 100% SURE YOU HAVE BACKED UP ALL OF YOUR SOUND PATCHES ON A FLOPPY DISK BEFORE BEGINNING THIS PROCEDURE!!! ONCE YOU START THE REPLACEMENT PROCESS, YOU HAVE ABOUT 30 SECONDS BEFORE THE BOARD LOSES ITS CHARGE AND YOUR SOUND PATCHES GET ERASED FROM THE ROM CHIP.***
Make sure you have all of the needed batteries and tools before beginning.
Hope this helps.
Nov 23, 2012 | Kurzweil Music Systems Kurzweil MARK152I...
I have a Mark V Kurzweil piano - the electrical ''box'' - not a technical term - just my description - in the back of the piano in which the plug attaches to go to the wall is disconnected in the piano -...
Your are likely talking about the input power connector. They are usually a three blade connector in a well.
If the connection is soldered to a circuit board, it has likely gotten bashed in. The circuit board MAY be cracked, but is likely repairable.
Take it to a local electronics repair shop or find one through a music equipment store that deals with pro audio gear.
USUALLY these connectors have "ears" that attach to the case for strength and if the connector has been pushed in the ears likely have broken off. The parts are USUALLY readily available from several sources including Digikey and Mouser.
Sep 24, 2009 | Music
Kurzweil Mark 10 keyboard stopped working
Try the reset procedure on page 5 ( last page ) of this pdf document:http://www.dgaudiorepair.com/PDF%20Files/HARD%20RESET%20for%20Current%20KURZWEIL%20.pdf Hope this helps. Note the first procedure says highest white key. I'd do the second procedure.
Aug 27, 2009 | Music
Replacement Battery Problems Kurzweil Mk 152
Check the voltage provided by the cells. Each cell should be above 3 volts. Make sure they are installed with correct polarity and the contacts are making. Brand new cells CAN be bad and some holders may not contact properly.
Jul 23, 2009 | Music
On power up there is a loud humming even with volume at 0
I would also be inclined to check all the larger electrolytic capacitors in the power circuits as well for AC bleed.
Feb 11, 2009 | Yamaha Electric Guitar
Open Questions:
See all Kurzweil SP4-7 76 Note Digital Stage Piano, Semi Questions
Kurzweil SP4-7 76 Note Digital Stage Piano, Semi Weighted Keys, 128 Programs, 64 Split Polyphony, Split Layer, Setup Mode, 24 Bit DSP Technology, Black Logo
500 people viewed this question
Top Kurzweil Music Experts
Rabbit Brains
Rabbit Brains
drivealot
john cordey
john cordey
Are you a Kurzweil Music Expert? Answer questions, earn points and help others
