Yesterday I had put connected the USB charger port to my ipod to charge it. When I did this I seen it said"HUB exceeded limit" or something like that. I also noticed that the internet was off as well and I have wireless connection. I discconected everything and then shut down the compiter thinking that this will refresh everything. When I went to turn the laptop on the computer turned on but the screen was black. I restarted the computer several times, but the screen was still black. I dont know what to do anymore because the omputer itself is on, but the screen is black. How do I fix this??
  • 536 Answers
Did you try disconnecting all USB connections from the laptop?
The "HUB exceeded limit" error message is telling you that you have too many things using too much power on your USB connections.
Please disconnect all USB connection, disconnect the power cord, and remove the laptop battery. Next press and hold the power button down for 30 seconds to drain away any residual electrical charge from your system
Install the battery and plug in the power cord again -- do NOT plug in any USB connections at this time.
Try to boot the laptop as normal. If the laptop does not boot as normal now, then you will need to take the laptop in for service.
If it does boot normally, only plug-in the USB adapters that you currently need -- one or two at a time in order to prevent future overloads.
If you absolutely need all of the USB devices plugged-in at the same time, then I suggest that you buy an powered USB HUB to plug all devices in to.
Posted on Jan 01, 2011
    Brigadier General:
  • 8,909 Answers
It sounds like the supply to the USB and motherboard has been overloaded and the fuseable link has failed.
It, unfortunately, is a job for the specialist as there are a lot of components that could be easily killed if static precautions are not adhered to and of course recognizing the faulty component, removing and replacing it etc.
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
Tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
on Aug 09, 2011 | Apple iPod touch
A usb has exceeded the power limits of its hub port
Simply put its what it says.
you have too many devices drawing power from the USB ports of your laptop.
A fix for this is to use a USB hub but it MUST be one with its own power supply.
Sep 07, 2009 | Microsoft Windows XP Home Edition
A USB device has exceeded the power limits of its hub port
Windows display this message when a USB device is short-circuited. Try another USB cord or connect the usb to the port at the back of your pc. If it does not help then the problem resides in the printer. I will not suggest to dismantle your printer as there are no user serviceable parts inside.
Aug 10, 2009 | Canon LaserBase MF5650 All-In-One Printer
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
Usb power surge
The Safely Remove Hardware icon list all removeable devices regardless whether it is a USB or PCMCIA or a removeable CD/DVD drive etc.
To get around the problem with your USB device that exceeds the power limit of the computer's USB port. Get a powered USB hub and connect it to the computer's USB port and plug the USB device into the powered USB hub.
Apr 06, 2009 | IBM ThinkPad T30 2366 Notebook
Hey,
Buy a usb hub with a power adapter.
this one for example
http://www.xpcgear.com/usbhubuh204d.html
Let me know if you need anything else.
Thanks,
Ekse
Feb 23, 2009 | Microsoft Windows XP Home Edition
Ipod
I think you have a sort in your ipod.
I will say a bad battery will cause this.
You have to open it and see if you make it to work without the battery.
Aug 04, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod
maybe bad ipod try another computer
Helpp! exceeded the power limits on its hub port?
try to change a new USB cord, and if it does not work the problem is a device then
Jun 21, 2008 | Vivitar MAGNACAM Binocular
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
