Question about Frigidaire Refrigerators
I have a Frigidaire refrigerator "Phsc39ejss" and
    President:
  • 1,891 Answers
Replace the main control as it has failed . the new one is improved .. mm feed back pls replace the sw membrain and the electronic control .. mm hope this helps .. feed back please
Posted on Jan 01, 2011
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Freezer digital temperature does not default back to 0. It slowly goes back up to 29.
Hello Terry, thanks for your inquiry!
From the information you have provided the temperature is not holding at 0°F inside of your Frigidaire refrigerator. Is your freezer currently cold? Does anything display on the front of the refrigerator? You may need to perform a reset on your refrigerator and you can do that by disconnecting the power cord for at least ten minutes. If this does not help resolve your issue I would recommend seeking help from a professional technician for proper diagnosis. This will help you avoid any unnecessary part purchases. -Matt
Apr 19, 2016 | Frigidaire FPHF2399MF Professional Series...
How do I test the digital circuit board that controls the temperature in refrigerator and freezer
Good Morning Friend,
I understand you are trying to test the digital circuit board that controls the temperatures for your Frigidaire refrigerator, model# FRS22ZRG. Typically, this is not a do it yourself test, as there are no step by step instruction manuals for this. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your refrigerator and determine what is going on with your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 12, 2014 | Frigidaire Refrigerators
Why did my frigidaire refrigerator digital temp display numbers just disappear after I tried to adjust them up? I tried resetting by pressing the on/off button to the left of the adjustment arrows-the...
Good Afternoon Friend,
I understand that the digital display, on your Frigidaire refrigerator, went out after trying to adjust the temperature. Without seeing the display, you will not be able to tell what the temperatures are set at, as well as if there is any trouble with the temperatures being hi, should that occur. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, if the display is still not showing, I recommend contacting your local authorized technician. The technician will be able to diagnose your refrigerator and determine why the display has gone out. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Frigidaire Refrigerators
Frigidaire refrigerator model ffhs2313lpo
The problem is most likely the=> 241739710 Temperature Control Board That is the electronic display that you said is not working. Sometimes there may be signs that the board is defective but most times there is no physical sign the board is defective, I am here should you need me, Thanks John Tripp Appliance 911
Apr 28, 2014 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
Frigidaire PLHS67EGSB1, the digital guage to set the tempoearture keeps chaning. set it at 0, day later might read 16, one tap down and goes back to 0. Next day might read 8, same thing. What can cause...
Most likely the=> 241608401 Thermistor and the=> 241608501 Freezer Thermistor You will need to begin somewhere and with the symptoms you are having it brings the controls the regulate temperatures to the top of my list for what may be causing this. PLHS67EGSB1 Controls item 21 and 21A are the thermistors I am here should you have questions, Thanks, John Tripp Appliance 911
uploads>parent.mediatoolbar.onimageuploaded('error with image');
Feb 13, 2014 | Frigidaire PLHS67EGSB Stainless Steel Side...
My Frigidaire PHSC239DSB2 side by side's digital temperture display is flashing a 2 on the freezer side & the fresh food sides temperature went up to 47 degrees, but has no flash. What is goin
HI this is a difficult one without a visual but i would sugest u disconnect the power supply.re-connect everything again and re-start.reset temp if not pre set.and try before u call an engineer.good luck.Ali
Jun 18, 2012 | Frigidaire FRS26H5AS Side by Side...
Frigidaire ffbc46fsls beverage center refrigerator does not resume "on" condition after power glitch. If the unit is unplugged while running, then plugged back in, it resumes normal function,...
Wow if you have lost that much because the memory dumps during a power failure then we are going to need do something serious about that! May take me a while to come up with a solution but being the case I think you have a serious point to make. Acording to The
Frigidaire FFBC46F5LS Beverage Center User Manual
and on page 7 of the PDF
The default temperature for the beverage cooler is 41°F (5°C). The temperature after power failure will be the temperature set before the power failure. So something is wrong with the control board part=> Pc board,input ,display I believe I would call USA 1-800-944-9044 and ask why that may be happening. Below is a parts list.
Frigidaire FFBC46F5LS Beverage Center Parts
Hope this helps, Thanks, Sea Breeze
Sep 03, 2011 | Frigidaire FFBC46F5LS
Refrigerators Logo
180 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
