Question about Uniden TCX905 Cordless Expansion Handset
Nav key stopped working
On both TCX905 handsets (of our Uniden TRU9485), the nav key stopped working in any of the four directions, probably due to dirt intrusion. Before tossing the handsets (aka the whole phone), is there any other option I could try?
TIA,
Park
  • fasaf Feb 17, 2009
    The nav key or the multi function key is not working on 4 handsets
  • Anonymous Apr 06, 2009
    for all 4 of my uniden phones tcx905, the scroll button is not working... bought new ones. but, i don't have a main base station to plug it in to to set it up... not sure what to do now. will continue to research and then call tech support
I had the same problem until today. This is what I did:
I opened up the handset and took most of it apart:
There are 2 screws in the battery compartment and you have to push something in on the sides to pull it apart. It won't come completely apart because there are wires connecting to the speaker. There are 5 screws on the inside that hold the board to the phone. I unscrewed those. The buttons are all on 1 rubber sheet. The problem is that the 4 metal connectors under the 4 way button (not on the board, the ones on the back of the rubber) have somehow deteriorated. To fix it I glued a very small piece of tin foil (I used a really thin brand) to each of the 4 connectors. They have to be done separately and the foil can't be too thick or the foil will be touching the board without a button press (found this out the hard way). Test it before tightening the screws to make sure everything worked and then put it back together.
Note: You may need to ground yourself so static electricity doesn't fry the board. If it breaks the phone, don't blame me :) I went this route because it was either play around to find a solution or buy a new phone. I don't know how long this will work for, but I hit all the buttons a bunch of times and they all work.
Posted on Feb 22, 2009
  • donaldh606
    donaldh606 Jul 27, 2012
    I found your solution yesterday. Tried it today with a bit of metal tape and now the handset works perfectly again!
  • Jared G Jul 27, 2012
    Just as a followup - it's apparently been 3 years since I did this and the phones I modified still work without additional tinkering. I did have to do it to another of the phones though.
Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Oct 03, 2009 | Uniden TCX905 Cordless Accessory Handset...
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
May 28, 2009 | Uniden Lands Phones
Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Aug 07, 2008 | Uniden TCX905 Cordless Accessory Handset...
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
ELBT595 & TCX905 compatibility
from uniden regarding your base station:
"This expandable base system is compatible with Uniden handset models ELX500, TCX400, TCX440, and TCX805. However, only the ELX500 is compatible the base system's Bluetooth and CellLink features."
Feb 09, 2008 | Uniden TCX905 Cordless Expansion Handset
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Oct 11, 2007 | Uniden TCX905 Cordless Expansion Handset
Uniden TCX905 Cordless Expansion Handset Logo
540 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
