Question about Garden
How to remove the sump oil from Hyter motif 48 push mower
    Novelist:
  • 171 Answers
The Briggs and Stratton motor does not have a drain plug on the bottom of the mower.
Today when you have your mower serviced at a repair shop they don't drain the oil. They **** it out of the fill tube with a vacuum. Since you don't have an oil vacuum just remove the dipstick and tip the mower over to drain.
Posted on Jan 11, 2011
Brand new mower cranks but won't turn over. Checked battery and spark plugs, all good. Where can I find an mage of the fuel pump to ensure it is installed correctly?
it is cranking but not running is the correct terms
there are several safety micro switches on the mower and all have to be in the correct positions to get it to run
seat -- you have to be in the seat
brake --you have to have your foot on the brake
blade drive --you have to have the drive in neutral
oil in the sump--- oil level switch is off if no oil in sump
There would have been an operators manual with the new machine so read it fully first as it not a case of get on and go
Dec 30, 2015 | John Deere D140 22HP V-Twin Foot Pedal...
Hyter ride on mower struggling to start. What seemed like fuel sprayed out of front right (exhaust)?! no fuel left in tank now. Please Help!l
your carb float is stuck open clean carb good remove plug and crank on it till no more fuel is coming out . also check crankcase as sometimes it drains to there . and could be overfull of oil/gas .
Jun 29, 2015 | Garden
Oil leak on deck of Lawn Mower
Because you mentioned the smoke and hard to start it could be that the engine is flooding or overfilled. Check for fuel in the crankcase. Be sure cranckcase is not overfilled. An engine with too much oil will force excess oil out somewhere. If the mower has been turned on its side lately it could have put oil in places that it should not be and its trying to burn off this oil. Be sure your air filter is not saturated with oil or fuel.
If all that checks out we will look for oil leaks.
As far as oil leaks go the three most likely places for your engine to leak are from the head gasket, dipstick tube seal, or the sump gasket.
Check for proper torque on the head bolts ( 125 inch pounds). Headbolts can come loose over time. After that check that the seal at the bottom of the dipstick tube is in good shape and a tight fit. This seal usually leaks when the engine is running because at rest the oil level is just below this seal. Lastly, if everything else checks out then the sump gasket is leaking. To replace the sump gasket drain oil from motor and remove air filter. remove blade and self propel belt. remove engine stop cable. remove the three motor mount bolts from under deck and remove motor. place on work bench upside down. some fuel may run out carb or tank cap. remove sump bolts from bottom of motor and remove sump. Do not remove governor gear or cam gear from cranckcase. At this time it will be obvious where the gasket has failed. Remove old gasket. It may need to be scraped off. Take care to keep material from going into crankcase and clean out any that does fall in. install new gasket and torque sump to proper specs and reassemble.
Jul 20, 2014 | Briggs & Stratton Garden
How do you replace a 3.5 hp briggs and stratton crank seal without taking the motor off the chassis or removing the oil sump cover?
your going to have to remove oil you dont have to remove sump after draining oil flip up on side remove blade and adapter you will see the seal take a seal removal tool pry out old seal reinstall in reverse
Jul 07, 2014 | Garden
Do i put an oil/gas mixture in gas tank?
the 4 stroke engine only needs petrol in its tank . if your motor has a dipstick for oil it is a four stroke ,,only two strokes requires oil and petrol mix as they have no oil sump in their design
Jun 01, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
My mower is spitting oil all over the driveway and smoking. The pull cord will not pull
It is important not to over fill the sump with oil, only fill to the max mark on the dip stick, if you have tipped the mower up it may have pushed oil up the engine breather and into the air filter box, if the paper filter is now soaked in oil you will need to replace the filter.
Apr 28, 2012 | Garden
How much oil does the sump require in a talon AM3050 lawn mower? Can't find my manual
It's very difficult to find information for this specific mower, however, most petrol mowers have a reservoir size of 1 pint / 0.5 litre. You should have a dipstick for checking the oil level anyway.
Basically, I suggest you drain the sump and add 0.5 litres of oil to ensure that the machine is neither low on oil or overfilled. Then call/email the manufacturer on Monday for clarification and/or a new manual.
Talon Tools contact:
tel: 1300 804 213
customerservice@husqvarna.com.au
Regards,
BElectric
Nov 06, 2010 | Mtd 22" Yard Machine Push Mower
Oil dripping on push mower deck
maybe from spilling that would be the best case. the worse case could be the sump gasket could have a tear in it and that would have to be replaced..good luck
Apr 09, 2010 | Garden
I need to know how to take out the camshaft and how to put in a new one on a 15 horse poulan rider
you must remove engine from unit. then loosen rocker arms and remove push rods. remove oil sump from bottom of engine. use a screwdriver to push lifters up,(a bit of grease helps them to stay up, very helpful at reassembly) and remove camshaft.
Jan 18, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Husqvarna YTH2448 engine leaking oil
That sounds like the sump gasket is leaking, sometimes the briggs machining at the sump and head areas are a little rough and a bad fit can allow the gasket to blow,if it is leaking it is actually sucking air in rather than pushing oil out while it is running. You would have to drain oil, remove the engine turn it upside down,remove the oil pump cover plate( 3 small screws) pull oil pump rotor and drive shaft out,remove sump bolts,replace gasket and reassemble.Be sure to use a light coat of gasket sealer like black silicone.
Jul 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
