Question about Logitech Webcam
When I put software in my PC does not show anything on screen to indicate how to install web cam
IB4G2008
  • 3587 Answers
SOURCE: web cam
www.logitech.com has some answers for you
got backup?
Posted on Feb 12, 2008
rizla
  • 1463 Answers
SOURCE: install web cam
if you try there web site you may need find the driver try here logitech hope this is so help ..
riz.
Posted on Feb 16, 2008
  • 13433 Answers
SOURCE: web cam
you can find logitech drivers from here
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en
Posted on Jun 15, 2008
robjac
  • 109 Answers
SOURCE: TULIP PC 2029R WEB CAM DRIVER
log on the websites of the product goto the download area or you check the download.com
Posted on Oct 17, 2008
RescueTechLA
  • 2653 Answers
SOURCE: i had lost my web cam cd of pc camera Web Cam :Qhmpl 500 Lm Drive
Go HERE.
Find your model, download and install the software.
Posted on Jun 15, 2009
How to install webcam without cd support
The make and model of the web-cam is not indicated. If your web-cam is not detected by the PC on itself on the default software, the you can always get the drivers from the reputed site of the web-cam.
So log on to the manufacturers website and download the driver, install the driver to your PC and then connect your web-cam to be detected and installed.
Nov 29, 2010 | Computers & Internet
My laptop is (HP) AMD Athlon II P320 Laptop (G62-244CA). and my web cam is HP WEBCAM 101, its not working. I have checked the device manager and it says that my web cam is working properly. But when im...
go to device manager, un-install your web cam and re-install with the drivers cd of web cam, also change the port of the cam els the cam may gone
good luck
Nov 05, 2010 | HP Computers & Internet
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
Hey iv just brought this laptop advent 6552 with a built in web cam. All i want to do is take picture's using the web cam but i can't because i don't know where to start for one and secondly iv looked...
hi when you boot your system go to the cmos settings a blue screen will show that is either you press f2 or f12 as your system requires, go to the on board settings i am sure the web cam on board is disables from this settings, enable it save the settings and exit. meanwhile on your windows xp make sure you have the webcam software installed this should work.
Jun 15, 2010 | Computers & Internet
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
Install intexit305driver
1. Go to: http://www.intextechnologies.com/webpages/download-driver.aspx
2. Under the "Download Drivers" section, click "PC Web Cam".
3. Click "Night Vision 500K (IT-305WC)"
4. Click "Win XP/Vista". This will start the download of your web cam's drivers.
Jul 01, 2009 | Computers & Internet
I want to download the web camera install to my pc kindly sujjest me
Get a USB web cam from Market- Put the disc- Install the driver & Software- than connect the cam to ur PC- it should start working
Feb 03, 2009 | Microsoft Office Outlook 2003 for PC
Webcam driver stops working during regular PC operation.
If the Web cam was Generic, or even Brand name, and it came with a Drivers disc (this would mean that it is not plug and play), try completely uninstalling the Driver software for the web cam. After the uninstall has finished, reinstall the drivers, taking extra care to follow ALL on screen instructions to the T. If at some point there were other web cams, and the drivers that belonged to those cams installed on the computer, be sure to fully uninstall all of them. Only use the cam and the drivers that you are attempting to install. After all of that, the cam should work just fine.
If for some reason the cam does not work after reinstalling the drivers, try a different brand of web cam. The computer that the drivers are attempting to operate on may not be adequate to support those drivers. If that's the case, try a generic, cheaper web cam as I said.
Also: While powering up the cam, don't run anything unnecessary.
Hope this helps.
Nov 22, 2008 | Computers & Internet
Logitech Webcam Logo
15 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
