Question about RCA P52926 52" Rear Projection Television
Why is there some sort of liquid dripping from our 20 yr old projection tv? We are taking it apart and what is it? Thanks
    Brigadier General:
  • 8,909 Answers
That will be the oil under the lenses to keep the tube screens cool. They leak over time and if it gets onto the electronice, it is conductive and will damage the circuits.
Posted on Jan 01, 2011
Liquid coolant in big screen tv, what is it?
It is a very toxic material called Glycol==if touched it gets absorbed into your body by contact--there to keep the picture tubes cool.
Lens should never be taken apart---if it got on the circuit boards it will short things out and start dissolving leads and the actual board as well.
Jun 15, 2012 | Philips Magnavox 51MP392H Rear Projection...
All of a sudden my 6 yr old samsung HCN653W has a
your cable box is effecting the component line in 1 or 2 in the back of the tv
Jul 12, 2010 | Samsung HCN653W 65" Rear Projection...
Liquide coms from RGB back projection tv.
The CRT will need to have new Coolant and new seals installed, and any circuit boards that were dripped on will need a very detailed cleaning to remove any residule as it can ruin the circuit board traces and solder connections
Jun 18, 2010 | Samsung HLR5087W 50" Rear Projection HDTV
On off switch blinking wont turn on
This seems to be common with this unit
the fix may cost between 300 and $400 according to my conversation with Toshiba guys.
here is a trial fix that is only temporary as i believe it will hget steadily worse.
FIX: Unplug and leave for 20 mins, replug and startup as normal.
Hope it helps, Please dont forget to give a rating to our expertise level
thanks Fiya team
Aug 12, 2009 | Toshiba 50H81 50" Rear Projection...
Mitsubishi 50" (14 yr old tv) rear projection TV
Yes this is the same as the others the voltage regulator is gone on your tv, replace it and take a good look at the power supply and horizontal ckt look for some cold solder
good luck
caypianan@yahoo.com
Oct 29, 2008 | Mitsubishi WT-46807 46" Rear Projection...
46" screen with an <8 x 11 picture!
you should contact samsung and inquire as to poss.warranty defects of this item
Aug 23, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Mitsubishi 10 yr old rear projection
Well, there is no lamp or simple part you can unplug and plug in. I have seen a couple of those sets with that symptom recently and it is caused by a faulty 9 volt regulator on the small signal board. This is not an easy part to change and the repair should absolutely be handled by a tech experienced in Mitsubishi projection sets.
Aug 09, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Liquid under screen
You need to take the screen off the front. You will find the screen comes away from the frame and seperates into two sheets. The liquid is seeping inbetween the two. If you clean it with Meths it should sort it without marking it.
Sep 04, 2006 | Toshiba 57H83 57" Rear Projection HDTV
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
