Question about LG Flatron L1750S 17" LCD Monitor
How do I reset the monitor to correct font size
  • 696 Answers
Hello Lawrie,
You don't actually adjust fonts or resolution on the monitor, you do adjust them in the control panel of the computer. To do this, open your start menu, select Control panel. When the control panel is open check the top left corner to see if it is in Classic or Category view, if it says Category, click the switch to classic mode link. If you don't see this in the top left look at the top right and look for Category or Large Icon View, if Category is selected select Large Icon by clicking on Category and then clicking Large Icon View in the list that appears.
Once in the proper view, click on Display and depending which version of windows you have select Settings on the top of the properties window(XP or older) or adjust resolution from the left column(Vista/7), now find the slider bar for resolution and slide it higher if you want the font smaller or lower if you want the fonts larger. This will set the number of pixels on the screen.
The default and best resolution for this monitor is 1280x1024, if that makes the fonts too small try 1024x768 next and 800x600 last. If the resolution is set too low to see the Ok and Apply button simply set the slider bar then press the enter button the first time, then you will be able to see the Ok and Apply if you need to continue adjusting.
Hope this helps Fixya,
Chris
Reply back with your version of windows if you require more specific instructions or pictures of any of the steps.
Posted on Jan 01, 2011
How do I change the font and icon size on the monitor. I have two monitors and font and icons are different sizes.
Change the Resolution of the 2 monitors to match the setting you prefer. (Right-Click on Desktop, choose "Screen resolution" It should show both monitors.Set resolution on the "Wrong" screen to match the settings on the "Correct" screen.
Oct 11, 2015 | HP W2007 LCD Monitor
Normal size for dpi
DPI, or "font size" is variable, depending on your monitor's native resolution, The resolution you have selected for it in Windows (Desktop-->Properties[right-click]-->Display Properties-->Settings), and what program you are currently using (browsers can be "zoomed").
I would try adjusting your monitor resokution first, before changing display font size. Try this page for some help with XP: http://www.andybrain.com/qna/2008/02/09/how-to-change-the-font-size-in-windows-xp/
This page for help in Win7: http://www.sevenforums.com/tutorials/443-dpi-display-size-settings-change.html
There really is no such thing as "normal" DPI font size. Most people with decent eyes would probably use 96 as a standard.
Jan 01, 2012 | Dell OptiPlex GX620 PC Desktop
How do I increasse the size of the font?
You can make the text and other items, such as icons, on your screen easier to see by making them larger. You can do this without changing the screen resolution of your monitor or laptop screen. This allows you to increase or decrease the size of text and other items on your screen while keeping your monitor or laptop set to its optimal resolution.
Nov 18, 2011 | Computers & Internet
How do you change the font size on the monitor
To change the font size, point your mouse to the desktop then right click. Click on Properties - Appearance (tab). The third option is FONT SIZE. You can adjust the size from there.
Hope this helps. Thank you!
Apr 06, 2011 | Hyundai X226W Monitor
My E72 font size became huge all on a sudden. I had selected Large font size in the settings, but the size became enormous all on a sudden and so I was forced to change it to SMALL. It is still larger than...
Go to Search... then type Font Magnifier... then just use the scale (press left or right) to change the size of the font you require... then Option to apply. It'll then re-boot itself and the size of the font should be corrected to the one you want.
Mar 08, 2011 | Nokia E72 Smartphone
I took a print of gmail i received= the print is very tiny i can
Yes! there is, what you have to do is Copy (Ctrl+C) the texts that you want to print and open Microsoft word (MSWord), Paste (Ctrl+V) what you have copied to the document then edit the font size.After you get the font size that you want, do the Printing. You can find the font type and font size options at the upper left of your Microsoft Word environment.... Good Luck.
If you have further questions, don't hesitate to post it here...
Feb 23, 2010 | Google Gmail
Need to increase font size without effecting pixel clarity
The first step for optimal readability is to set your PC's graphic output to the native resolution of your monitor.
The Samsung 2033SW is a little unusual in this regard since it provides a matrix of 1600 x 900 pixels, which is not very common.
If your graphics board has DVI output, I'd also make sure to use a DVI cable to connect to the monitor instead of VGA.
Windows XP and above support a font rasterization technology called "ClearType", see http://en.wikipedia.org/wiki/ClearType. This page also provides references to the ClearType tuner PowerToy for XP, which is available to Windows users at no extra charge. Windows 7 has a control panel for ClearType out-of-the-box.
If you still need to increase font size, you can increase it from the Display Control Panel, too, "Medium" font size scales to 125'%, "Large" fonts to 150% the normal size.. Changing the DPI (dots per inch) setting in the monitor control panel cannot be recommended since some software cannot cope with alterations here (dialog boxes or user interfaces with text in wrong places or sticking out of the window... yeeks.)
Feb 07, 2010 | Samsung Syncmaster 2033SW Monitor
How to unlock LG monitor controls? whenever I try to use monitor controls for brightness settings etc it gives a message "controls locked"! please help me to resolve this.... thank you!
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } Try pushing the menu button and the right arrow button on the monitor together for about three seconds. The message "controls unlocked" should appear.
Please don't forget to rate this solution.
Jun 09, 2009 | LG Flatron L1715S 17" LCD Monitor
The font size of my N70 has suddenly reduced and i don't know how to correct it.
have you ever heard about resetting?
´just do a reset on your cellphone by pressing:
*#7780#
put your security code wich will probably be 12345 if you never changed it.
sincerly.
steven joseph picasso
Kaculo@hotmail.com
Apr 25, 2009 | Nokia N70 Cellular Phone
Changing font size for larger monitor.
You can adjust your settings to something more to your liking by right clicking on your desktop in an empty area - then choose "properties" from the menu that pops up.
In the new window go to the tab that says "settings" and adjust the screen resolution to something a little larger. If you change your desktop settings in this manner then a window will pop up immediately after the adjustment asking you if you want to keep the new settings or revert back to the old one. If you don't select something within like 15-30 seconds it will change back. It does that just in case you change the settings so bad you can't see anything.
Another place to adjust the size of your fonts is to go to the "appearance" tab of the same menu and look for "font size" and there you can make your fonts bigger and ridiculously big, in case you still need to after changing the resolution.
I hope you find this information helpful, have a blessed day!
Dec 12, 2008 | Dell E173FP 17" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
120 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
