Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My 420 c won't steer to the left. I've made all the proper adjustments of lever, throwout bearing, and brake band. The tractor carries on straight ahead when I pull the lever all the way back as if the clutch hasn't disengaged although the throwout bearing moves as it should and the brake band tightens in sequence. The right side works fine with the same adjustments. Any thoughts on this will be appreciated.
  • 3 Answers
I'm not familiar with your system but it sounds like you could
have a bad pressure plate.
Posted on Jan 02, 2011
How to adjust throw out bearing
There is no adjustments on a clutch throw out bearing.
Nov 07, 2016 | Cars & Trucks
Adjusting the brake and steering clutches on a john deer 350b dozer
o athat mean the clutch adjustment is too tight and does not totally engage? I had a full load in the bucket and when backing out, would not back straight out but kept turning because the left track was not pulling. I pulled JDEMARIS instructions and tried to follow them. On the left, the ball joint link is adjusted all the way out, no more adjustment. On the right, the 3/4 brake bolt will not turn. The head acts like it is recessed in the lever and will not turn the 180, either direction.
Another problem, the foot brake does not work. The linkage under the floorboards acts like it is not connected to anything at the rear. Where is it supposed to connect? I can udjust the yoke on the linkage all the way either direction and no change. The pedal goes to the floor with no effect.
Sep 28, 2016 | Garden
Model YTH180 tractor. Why does it go fine in forward but reverse is slow?
Linkages to the transaxle may be wore or out of adjustment also check the brakes they could be binding while reversing.
Low ground speed: If the linkage is not synchronized to absolute neutral, or the shift lever is not properly fastened to the tapered control shaft, full forward / reverse travel may not be achieved. This may cause a false reading and be misdiagnosed as a low power condition. This also could be caused by the brake not releasing.
To determine absolute neutral, the hole in the tapered control shaft must face straight up and down, at this point make sure the OEM linkage is in neutral. To properly fasten the control lever to the shaft, torque the nut to 25-35 ft. lbs. (34 - 48.3 Nm) of torque with the shaft and the lever in neutral. When attaching the shifter arm to the shaft you must prevent any rotation during torquing. This can be done
by placing a long 5/16 bolt in the hole of the shaft. Hold the bolt until the tapers are locked and the nut torque is correct. To make sure that the brake is not binding, drive the unit up a slight grade.. Position the speed control lever into neutral. The unit should coast backwards. If the unit does not coast back slowly, the brake is not
released from the brake disk. Adjust the brake linkage to release the brake completely when the foot pedal is released.
Feb 16, 2016 | Husqvarna Garden
Steering drift it wanders
If this is a zero turn machine you can adjust the drive control levers and tracking so that the machine will track straight rather than go to one side or the other. There are adjustable links at the bottom of the control levers between there and the transmissions that can be adjusted in order to fix your problem.
Feb 06, 2016 | Garden
265 Massey Ferguson clutch won't release
Broken fork, broken shoulder on throwout bearing. Bearing seized on transmission shaft, broken pivot
Jan 31, 2016 | Toys
Change breaks sears tractor model 917.25640
http://c.searspartsdirect.com/lis_png/PLDM/00027588-00003.png
On the sears site the brake band is part number Brake band PART NUMBER: 634A167
Substitution: 101230K . The band is number 17 on the parts diagram. You'll find it on the rear left side. If the band is in good shape ,it can be adjusted by turning the turnbuckle on the brake rod.
Jun 07, 2014 | Sears Garden
I need to know how to replace the clutch in a 1993 colt vista
Fig. Fig. 1: Clutch release bearing - 1990 Colt hatchback and sedan w/ 1.6L engine, 1990 Colt Wagon w/1.8L engine, and 1990-93 Vista
Fig. Fig. 2: Clutch driven and drive discs - 1990-93 all models
Fig. Fig. 3: Clutch release bearing - 1990 Colt Wagon w/1.5L engine, 1991-92 Colt hatchback and sedan w/4-speed and 1993 Colt hatchback and sedan w/1.8L engine
  1. Remove the transmission or transaxle as outlined.
  2. Insert a pilot shaft or an old input shaft into the center of the clutch disc, pressure plate, and the pilot bearing in the crankshaft.
  3. With the pilot tool supporting the clutch disc, loosen the pressure plate bolts gradually and in a crisscross pattern.
  4. Remove the pressure plate and clutch disc.
  5. Clean the transmission and clutch housing. Clean the flywheel surface with a non-oil based solvent. Wash your hands before installing or handling the clutch assembly parts. Hold the clutch disc by the center hub only.
Before assembly, slide the clutch disc up and down on the transmission input shaft to check for any binding. Remove any rough spots with crocus cloth and then lightly coat the shaft with Lubriplate.
  1. To remove the throwout bearing assembly: Remove the return clip and take out the throwout bearing carrier and the bearing.
  2. To replace the throwout arm use a / 16 in. punch, knock out the throwout shaft spring pin and remove the shaft, springs, and the center lever.
  3. Do not immerse the throwout bearing in solvent; it is permanently lubricated. Blow and wipe it clean. Check the bearing for wear, deterioration, or burning. Replace the bearing if there is any question about its condition.
  4. Check the shafts, lever, and springs for wear and defects. Replace them if necessary.
  5. If you hadn't planned on replacing the clutch disc, examine it for the following before reusing it. Loose rivets. Burned facing. Oil or grease on the facing. Less than 0.3mm left between the rivet head and the top of the facing.
  6. Check the pressure plate and replace it if any of the following conditions exist: Scored or excessively worn. Bent or distorted diaphragm spring. Loose rivets.
  7. Insert the control lever into the clutch housing. Install the two return springs and the throwout shaft.
  8. Lock the shift lever to the shaft with the spring pin.
  9. Fill the shaft oil seal with multipurpose grease.
  10. Install the throwout bearing carrier and the bearing. Install the return clip.
  11. Grease the carrier groove and inner surface.
  12. Lightly grease the clutch disc splines.
The clutch is installed with the larger boss facing the transmission.
  1. Support the clutch disc and pressure plate with the pilot tool.
  2. Turn the pressure plate so that its balance mark aligns with the notch in the flywheel.
  3. Install the pressure plate-to-flywheel bolts head-tight. Using a torque wrench and, working in a crisscross pattern, tighten the bolts to 11-15 ft. lbs.
  4. Install the transmission or transaxle as outlined.
  5. Adjust the clutch as described in the following information.
Jan 07, 2013 | Cars & Trucks
1983 john deere 420 garden tractor thats stalling out when barely moving the hydrostactic lever or trying to engage the front or rear PTO
There are 2 safety switches on that unit as well. Most of them are right below the steering column in the firewall area. Search that to see if that unit has them. I'd be willing to bet one of them is faulty. Most are just a push button type.
Oct 18, 2017 | John Deere 420,1020,2010,2020,2510,2520...
After several years my parking brake won't engage. I've adjusted the brakes tighter & looser but still can't engage pking brake.
The brake pad is probably worn out then. It is a little tiny thing. I know that on my Craftsman that is is attached to the right rear axle. You have to remove the right rear tire to access it. Check that the mechanism works properly and not hung up while you are there.
I hope this helps.
Jul 23, 2011 | Garden
When pulling in the clutch there is a loud squalching noise.
Sounds like your clutch throwout bearing is either bad or going bad. This is due to improper clutch cable adjustment. Just like in a straight shift automobile, if you keep your foot on the clutch pedal, the throwout bearing runs continuously shortening the life of the bearing. On a motorcycle, if the clutch cable is not adjusted to have just a bit of freeplay in it, the bearing will run continously as well shortening the life of the bearing. But, then again it could have just been a faulty bearing.
To repair the problem, you must remove the outer primary cover. First, drain the primary/transmission oil. Then you must loosen the primary chain adjuster beneath the primary cover. Loosen the lock nut and turn the adjuster bolt outward to lower the adjuster shoe inside the primary.
Then remove the clutch inspection cover, the small spring, and the locknut on the clutch release mechansim. Remove the left hand foot peg. Remove all the bolts holding the outer primary cover on. As you remove the primary cover, you will have to turn the screw inside the release mechanism inwards to get it out of the release mechanism.
Once you get the primary cover off, you can see the clutch throwout or release bearing in the center of the clutch assembly. Remove the snap ring and pull the bearing out. Inspect and replace the bearing if found to be defective. Carefully drive the center bolt out and the bearing out of it's holder. Install in the reverse manner.
Reassembly is reverse of disassembly. Install a new gasket on the primary and slide the primary cover in place while turning the clutch release screw into the the release mechanism. Install the bolts that hold the primary cover on and tighten. Tighten small primary cover bolts to 80-110 Inch pounds and the left foot peg bolts to 16-28 Foot pounds.
Adjust the primary chain tensioner to obtain 3/8' to 1/2" up and down slack when checked through upper inspection cover on outer primary. To adjust the clutch cable, find the bellows looking cover over the cable adjuster. Loosen the lock nut and adjust the cable as short as possible. Back at that the adjuster on the primary cover, slowly turn the adjuster screw clockwise until it bottoms out and quits turning. Do not force the screw to turn, just until it bottoms out. Now, back it up 1/4 turn and install the locknut. You may have to turn it just a bit one way or the other to get the locknut in. Install the spring and the cover with the quad ring in place. ADD OIL TO THE PRIMARY, 32 OUNCES of H-D Sport Trans or equilivent. To adjust the cable, adjust cable adjuster in the middle of the cable out as far as it will go without forcing anything. Squeeze the clutch lever a few times and adjust the adjuster so that you have 1/16" to 1/8" freeplay at the lever, about the thickness of a nickle between the lever and lever stancion. Lock the locknut on the cable adjuster and reposition the bellows cover.
As you can see, this is not a very difficult job but it is not for the "faint of heart" since it involves removing the primary cover. I would rate the job difficulty as "moderate" due to this necessity. The only special tool required would be a set of snap ring pliers. Good Luck!
Feb 14, 2010 | 2003 Harley Davidson XLH Sportster 883...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
97 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
